Has anybody install a hitch yet? I am thinking of going the Curt route as that is what I have used in the past. If you have a hitch...how was the install? Pics?
You can use either a Curt 1-1/4-inch Class II hitch # C12108 or the 2-inch Class III hitch # C13149. There is a installation video on the etrailer site.
The T-One Vehicle Wiring Harness with 4-Pole Flat Trailer Connector #18578 works for the light hookup. It also has a install video on the etrailer site.
I have installed both on my 2016 Hybrid Rav4 with minor adjustments.
Hmmm... If I don't want the lights, is the install much easier? At this point we have no trailer to pull, nor do we desire to pull a trailer. Ideally, I'd want to have a hitch that requires no modifications to the RAV4 Hybrid.
I'm debating whether or not to use my existing 2" Yakima Kingpin 4 hitch mount bike rack from my old Prius. The reason I went with a 2" hitch was because the bike racks are beefier. The other alternative would just be to invest in a roof rack, which might come in handy in the future if we get the kids out on to ski hills when they get a bit older.
And yes, I really had a 2" hitch on my Prius, but it was only for bikes. However, most rack places wouldn't even install a 2" hitch on such a car. The 2" I got was a custom design specifically for the Prius by a small third party Prius accessories maker.
Anyone planning to use the Curt 12108 1 1/4" hitch for a bike rack should note that Curt's warranty requires that you use a stabilizing strap for any non-trailer load.
From this thread I ordered the C13149 2 inch class 3 hitch. Went to install today and found it did not fit as shipped. Just not wide enough to line up with the chassis holes. Close, so I am hoping tomorrow to use my body jack and expand the width of the flanges another 1/2 inch. They appeared to be slightly bend inward. Putting a bolt in once side and then trying to pry the other side wide enough to start the bolt, just could not do it. Otherwise if I am successful to straighten the flanges this hitch should work fine.
I installed a 2 inchCurt hitch on my 2015 Limited. Easy install. Frame is pre-drilled for hitch. I have a Thule bike rack and it works great. The bike rack will fit a two inch or one and a quarter receiver.
Success today ! Apparently I just received a hitch that shouldn't have made it past the QC department. I used my body jack and expanded the flanges about 1/2" until they appeared to be straight. Then installed with no problems.
Has anyone installed this Curt hitch (13149) on their RAV4 hybrid? Any fitment issues? What Curt wiring harness did you get? The Amazon website says this hitch is not compatible with the hybrid?
The thread right before mine says his car is a RAV4 SE, that's not a hybrid. The second part of the question about the wiring harnesses I haven't seen mentioned with part numbers...I skimmed
The 4-wire pigtail to the trailer is just laid in the opening of the hatch and connected to the trailer, the hatch will easily close on it, when not in use it's stored under the rear deck with the spare tire, watch the video.
I have not run the wiring yet, but like you, originally wanted to mount the connector by the hitch. But when I got to thinking about it the connector stays a lot cleaner stored inside the vehicle. And that makes for a lot easier installation.
What dwrede said, I've had dozens of vehicles with hitch mounted receptacles, the 4 pole flat connectors can get corroded , the flimsy caps eventually come off and don't seal all that well in the first place, I've also had the wiring ripped off by brush growing up in the middle of the track on old logging roads, having the wiring stowed inside except when in use is a great option IMO. I only tow once in a while, so no need to have the wiring out in the elements all the time.
Last 3 vehicles all had 4 wire and 7 wire external connectors with caps, never had one problem with them. I will mount mine on the outside, just seeing if / how folks have routed the wire out. Had all 3 vehicles for a minimum of 15 years..
Has anyone done the hitch install and wiring already on the Hybrid 2016?
Do we really need to modify the plastic cover? If so what did you use to cut it?
For the wiring, does it just connect to the wiring harnesses in the back of the vehicle on both the driver and passenger side underneath the wall panels? For a hybrid, is there still wire you need to thread to the front? Or since the battery is in the back you can just connect it to the battery there and the ground? I'm ok with storing the extra wire in the spare tire compartment.
Thanks for your help! I have never installed anything before... so this may be a challenge for me but I appreciate your posts!
Any good suggestions for a bike rack that connects to the hitch? Or have any of you had any problems with trunk mounting bike racks? Like do they damage the exterior of the car over time?
Did you read this thread, or just post your question without reading it? See dwrede's reply(#16) down the page. I trimmed the plastic cover with metal snips, you only need to remove a corner to allow clearance for the hitch install, it's the same as the 2015. I installed the Curt C56166 on my 2015, will use it on the Hybrid as well.
I did read through the entire thread but just want some more clarification on installing on the Hybrid. If anyone has photos of where they cut the plastic or how they installed the wiring to battery, I'd really appreciate it!
I apologize but I have no experience with installing these types of things.
My hitch is a DrawTite 75235. Install will be the same across hitch makers.
This is on my 16 hybrid limited
Step 1 - Take off driver side cover, 2 clips - 1 nut(10mm). Put aside will not be reused
Step 2 - Remove hold down bracket drivers side. Bolts will not be reused bracket will(17mm)
Step 3 - Remove unused exhaust mount bracket(12mm)
Step 4 - Lower exhaust by pulling off rubber bushing(I didn't do this step as I was able to install the hitch in place and tighten the bolt using a swivel socket.
Step 5 - Install hitch - 2 bolts in pass side and 3 in drivers side. Install the closest to the front bolt on the drivers side first, then install the hold down bracket removed in step 2 over the hitch. See pictures (Bolts in my kit were 19mm)
This is all do able in about 20min, I lifted the hitch into place by myself, although a 2nd person would be helpful for that step.
I will be doing the trailer wiring in the next day or 2.
Just ordered the cheapest listing on ebay with the $20 coupon code. Now I just need the trailer lights.
eBay.com offers $20 off Orders $100 or more on Auto Parts & Accessories and Automotive Tools & Supplies when you enter promo code CMOTORS616 at checkout and use PayPal as payment. Shipping varies depending on items chosen. T
https://www.etrailer.com/question-152217.html
2 Inch Hitch Recommendation for a 2016 Toyota Rav4 Hybrid Limited
Question:
Can you please give me part number for a 2 inch receiver trailer hitch for a 2016 Rav 4 hybrid limited. Thanks
asked by: Vince
Expert Reply:
I can help you get a 2 inch trailer hitch for your 2016 Toyota Rav4 Hybrid Limited.
I recommend the 2 inch Draw-Tite Hitch # 75235 for your Rav4 Hybrid Limited, because it is a no drill application and the best bang for your buck.
I have the Curt 2 inch class III hitch #C13149. I am going to replace the hitch with the hidden hitch. Anyone in the Seattle area want a almost new hitch for cheap?
Looks totally different, but the biggest thing is that the curt ground clearance sucks. I have bottomed it out a few times in crappy parking lots. HH gives a few extra inches in clearance.
147.9K members
