Trailer Hitch Install Advice - Page 3 - Toyota RAV4 Forums
post #21 of 58 (permalink) Old 07-23-2016, 03:04 PM
You really should do it yourself ... It took me about 30 minutes with a problem on my Rav4 2014 .
front2k is offline
post #22 of 58 (permalink) Old 01-25-2017, 02:25 AM
Originally Posted by jlwatts View Post
Here is part of the tips that I shared for the Hybrid that might be helpful to you:
Installing Hitch and Wiring
I chose the 1 1/4 hitch because I use it primarily for a bike rack and for an occasional trailer pull. It is also available in the 2 inch size.
Actually, on the eTrailer site Curt hitch there are numerous pictures and a complete video for the hitch install and the page for the wiring kit also has a good installation video.
These installs apply to the 2013-2016 Rav4.
Modifications for the hitch - cover panel to modify:
The 2016 RAV4 Hybrid has a plastic cover panel covering the tie down rack. It was easy to remove, but it had to be modified and replaced after the hitch installation. I just used a cutting tool to cut away a small part of the plastic cover to make room for the hitch before reinstalling.
Trailer Hitch Site:
https://www.etrailer.com/p-C12108.html
Hitch Wiring Kit:
https://www.etrailer.com/tv-install-...v4-118578.aspx
If you are going to do the wiring yourself .... you will need this "Trim Panel Tool" or something similar:
https://www.etrailer.com/Tools/Power...ALL648544.html
The part numbers are C12108 for the hitch and 118578 for the wire harness.
They are on the etrailer.com web site.
I hope that helps.
What trailer are you using? Also, does the hitch fit on a 2017 rav4?
ucwarrior1 is offline
post #23 of 58 (permalink) Old 01-25-2017, 02:33 AM
I may be special but the larger weight option is the cheapest...what's the true difference between these three?
https://www.etrailer.com/hitch-2017_Toyota_RAV4.htm
post #24 of 58 (permalink) Old 01-25-2017, 12:21 PM
Quickdtoo's Avatar
Biggest difference for me is Curt is made in the US, dunno about Drawtite, there's no mention of where they're made on the Drawtite website, the first Curt has a 2" receiver opening, the bottom Curt has an 1¼" receiver opening, they all have different weight ratings that exceed the Rav4.4 limits.
2016 Hybrid Limited AWD
Quickdtoo is offline
post #25 of 58 (permalink) Old 01-25-2017, 12:28 PM
So basically the cheapest one is the best option? Does the 2" opening have a benefit over the 1 3/4"? I'm newer to this whole thing..Clearly.
post #26 of 58 (permalink) Old 01-25-2017, 01:19 PM
Looking to purchase one tonight!
post #27 of 58 (permalink) Old 01-25-2017, 01:59 PM
Quickdtoo's Avatar
Go for the Curt 2", that's what I bought, it's very popular here on the forum. If you want something hidden(only the receiver tube is below the bumper cover/valance), the Torklift Ecohitch is the only choice, but it's close to $300.
post #28 of 58 (permalink) Old 01-25-2017, 09:21 PM
Country: Deputy347k9's Flag is: United States
I have a 2017 RAV4 XLE. I purchased the Draw Tite #75235 which comes with wiring kit #118578, total cost was $162.00 shipped to me in NC. This was the easiest install I have ever done. The wiring kit was a bit tougher. Purchased a six piece plastic inteirior tool set that was a great help. Installed the hitch in about 45 minutes, the wire harness took about 2 1/2 hours but could do it again in 1 1/2 hours. The Draw Tite that I purchased is a 2" unit. I have a 5'5"X10' aluminum trailer that hauls like a dream.
Deputy347k9 is offline
post #29 of 58 (permalink) Old 01-26-2017, 02:48 AM
As I said I'm a bit newer. This should fit a 2017 hybrid rav4 correct? I know the battery is in the back so wanna make sure this is correct. Is this wiring kit only for the lights or does it cover the brakes as well?
post #30 of 58 (permalink) Old 01-26-2017, 03:30 AM
So here is one listed exactly in the range for the Rav4. I also stumbled across this little guy..
Top 10 Ultra Lite Travel Trailers Under 2000 lbs
