Hi guys. Just got my new 2014 XLE yesterday coming from an FRS.
I wanna transfer my Radar and Dashcam over to my RAV4 but I can't seem to find any hardwire or install DIYs around here.
Maybe someone can help me out?
Use some trim removal tools to remove the dome lights and buy a hardwire kit with an inline fuse. I also have my escort passport 9500ix mounted under the mirror.
To remove the cover just give it a good yank. Start in the rear and pull straight down. Two tabs should release. Then slide your hands as far forward as possible and keeping the cover as parallel to the roof as you can, pull straight down to release the front.
I am going to try this as well. Which 12 volt connector do I use? The switched 12 or the constant 12? Also, I take it that this is the connector that goes into the motor and not to the switch
If you hook to constant 12 the device will always be on unless you manually turn it off. I used switched 12 volt with my dashcam and the device turns on when I start the CAR.
