Since I bought the XLE for the wife, the only complaint I have about the car is the lack of an automated lift gate/trunk opener. Does anyone know if there is an OEM or aftermarket kit available?
Yes, I was wondering about this too. I am not sure what has to be done. There is motor install, hookup, and I wonder about keys (would we need new ones).
FYI - I am not sure if you can edit your post, but it has lifegate
I wonder how easy it would (not) be. I would think you could probably get it to where you could open it from within the vehicle but does the key button tie into the entire system or does it work on a separate transponder that you could retrofit as well...
I'm thinking this would not be an easy install, and doubt that the vehicles come pre-wired.
I have a 2013 XLE that does NOT have an auto lift gate... I wish it did.
The ones I looked at which did had a button on the dash and a button on the lift gate in addition to the extra button on the remote (and with that you would need a new chip in the key and I'm not sure how you would get it programmed since the dealer likely would only flash to your car which wouldn't include an auto-lift gate? Not sure if that is an option they can add with their software and getting new keys flashed is NOT cheap even if you bring all the stuff to them... I lost one with my prior car).
At best I'm think you would have to run all the wiring, and only open/close it from the car and not the key.
Not sure if it is related, but I watched video instructions when installing my hitch wiring. That was a 2013 Limited. Under the car was extra wiring going to the back area which is not on my 2013 XLE (came up through a grommet on the drivers side behind the rear wheel). I was wondering what that extra wiring was for, perhaps this is it.
