#1
Sep 19, 2014
(Edited)
They fit, but need spacers up front to clear the brakes. Good ride still and much better stance.
edit: more info below.
stock wheels/tires:
- XLE : 17 x 7" 225/65/17 = 28.52 tire diameter
- Limited : 18 x 7.5" 235/55/18 = 28.18 tire diameter
- Highlander : 19 x 7.5" 245/55/19 = 29.61 tire diameter (5% speedo error slower)
Wheel hub: 5x114.3 • Center Bore: 60.1 • (use at least 3mm hubcentric spacer to clear front brakes)
See less
See more
1
#5
Sep 20, 2014
looks great. you can also get the 20 inch venza rims for an even more OEM upgrade
#8
Sep 22, 2014
Did you do that? Didn't really like the Venza rims...
0
#9
Sep 22, 2014
ST looks awesome... 5*****
question: measurement of the spacers did you use it?
only spacers in front wheels? rears as well? tire size did you use it? oem highlander 245/55R19?
thanks a lot.
best upgrade for 4.4 rav4
#11
Sep 23, 2014
Thanks!
I used 5mm spacers on both front and back (rears weren't needed but I wanted neutral handling/track). I used oem highlander tires since I bought them with it.
0
#12
Sep 23, 2014
They look really nice!!!
Hows the handling since you're running on larger wheels?
#13
Sep 23, 2014
Similar, maybe slightly better. I do notice that acceleration has taken a very slight hit (heavier), as well as mileage, but still worth it imho. The visibility has improved too, since it is slightly higher.
0
#14
Sep 30, 2014
updated with more info on first post and better pic below
