I had a look at my RAV4, but could not see much.. Whatever you do,
1. Try to use a 'plastic' pry tool and some masking tapes, consider not to use a metal screw driver...
2. Before trying to pop the mirror, I would try and shine some light through the gap to the back of the mirror at night or in the dark just to see if the mirror is indeed "translucent"...
I have installed LED arrow panel (see pictures). It's easy to add this arrow turn signal to the side mirror. But not easy to run wire through. Mine is RAV4 LE. It does not have turn signal harness in side view mirror. I have to run wire from instrument panel to side view mirror.
