Do I Really Need These or Am I Being Scammed Again? - Page 2 - Toyota RAV4 Forums
post #11 of 37 (permalink) Old 12-21-2016, 01:13 PM Thread Starter
Country: My4thRAV4's Flag is: United States
Originally Posted by whipaway View Post
You forgot-
Paint Service
Item description
A new, fresh coat of paint is applied to your vehicle.
Reason
Over time, airborne abrasive particles, sunlight, ozone, bird droppings and other environmental issues can damage the surface of your vehicles paint. This can cause the underlying metal to rust, reducing the visual appeal of your vehicle and also its resale value. If left untreated can result in metal perforation.
This made me bust out laughing but then...scary because I seriously wouldn't be surprised if they did.
My4thRAV4 is offline
post #12 of 37 (permalink) Old 12-21-2016, 01:22 PM
what you should do is get yourself a reputable independent mechanic, ask around friends and familly
2007 Rav4 V6 Sport AWD (bought back after dealer messed it up)
2012 Rav4 V6 Sport AWD, setup for towing with p3 brake controler, airbags rear helper springs, 15k atf cooler.
Toys: 2008 Doral Sunquest 170, 2016 Princecraft Vectra 19, 2011 Jayco Swift slx 154bh
Octane is offline
post #13 of 37 (permalink) Old 12-21-2016, 01:41 PM
Country: BourneSupremacy's Flag is: United States
BourneSupremacy's Avatar
The times I've been in the market for another car I'm always amused at what the so-called *FINANCE MGR* has to say about extended warranties....something you can get on your own if the car is brand new from your own insurance company for more than half than what the dealer charges....
BourneSupremacy is offline
post #14 of 37 (permalink) Old 12-21-2016, 02:02 PM
Country: RAVN4RED's Flag is: United States
RAVN4RED's Avatar
Originally Posted by My4thRAV4 View Post
Well that's just great! I paid $113 for labor, $18 for parts, and $18 for "shop supply"!! Well I guess my RAV4 wont ever be needing brake flush for another 5yr/60k!
Next time I'm taking the Maintenance Schedule book with me at my next service.
If the only thing you did from the mess the Dealer suggested, you came out okay. After all, the Canadian Schedule says 4yr/40k miles for the brake fluid change, so according to that at 44k you were 'due.' And yeah, you should rest easy about brake fluid till you hit 100k or so! The other stuff was overpriced and bogus.
When I was in for some warranty work, the dealer quoted me $250 for a brake flush. Uh. No. Thanks. So your price doesn't seem to bad, the labor charge seems reasonable for about an hour. Of course, that assumes they even did anything.
The point of my earlier post is there are a lot of opinions on this--even between Toyota Canada and Toyota USA. And since my Canadian built RAV lives in weather similar to Canada, I'm using their schedule! My own feeling about it is that the USA schedule (no brake fluid service at all) is flawed, if concerned about long term ownership.
2009 Red RAV4 Base I4 AWD
1989 Chevy Silverado V8 4WD
2004 Yamaha FJR 1300 I4 1WD
RAVN4RED is offline
post #15 of 37 (permalink) Old 12-21-2016, 02:43 PM
Country: CARZWAUSAU's Flag is: United States
CARZWAUSAU's Avatar
So glad I lease. Fuhgettaboutit!
Sent from my iPhone using Tapatalk
CARZWAUSAU is offline
post #16 of 37 (permalink) Old 12-21-2016, 03:23 PM
RAVN4RED's Avatar
So when you said earlier brake fluid is good for the life of most vehicles, you meant life of a lease? True that.
RAVN4RED is offline
post #17 of 37 (permalink) Old 12-21-2016, 05:06 PM
Country: Grand Total's Flag is: Canada
The last time I had a finance manager try hard to sell me an extended warranty by "scaring" me with the thought of large repair bills I said "You know I'm not sure this is the right car for me if it's so prone to problems". She backed off pretty quickly.
Grand Total is offline
The Following User Says Thank You to Grand Total For This Useful Post:
pico (12-21-2016)
post #18 of 37 (permalink) Old 12-21-2016, 05:16 PM
Blogson's Avatar
Not to the extent that it needs to be flushed during the life of most vehicles.
RTexasF (Post #6) is correct.
I have a tester and test the brake fluid in my RAV for moisture. After 2-3 years the tester shows the brake fluid has absorbed enough moisture so that it should be changed. Also moisture in brake fluid will corrode metal brake system parts with which it comes into contact.
Jim
2011 Upgraded Base V6 4WD
2002 Craftsman LT1000 V2
Jesus is Lord
Blogson is offline
post #19 of 37 (permalink) Old 12-30-2016, 04:46 PM
Country: ashchuckton's Flag is: United States
ashchuckton's Avatar
Most of those services are a cash cow for the dealer. Changing the brake fluid is not one of them. As has been said ALL brake fluid absorbs moisture.
That does two things & both are bad.
1. The moisture moves to the lowest parts of the brake system causing the pistons & cylinders in the brake calipers to corrode. Not a cheap fix when it happens.
2. The moisture contaminated brake fluid now has a lower boiling point. In hard use your brake fluid will boil. That equals no brakes when you need them. Spend the money on this service it can save you, your family & other road users.
PS: It is due every two years.
ashchuckton is offline
post #20 of 37 (permalink) Old 12-30-2016, 05:33 PM
Wow, what a bunch of crooks! I work for a Toyota dealership and none of that is required for your RAV4. However on German cars the brake flush is necessary when you have dot 4 brake fluid which absorbs water as it states. Toyota only uses dot 3 fluid, so you are fine.
I think this is incorrect advice. DOT 3 brake fluid definitely does absorb water, otherwise why would the DOT 3 certification include tests for both wet and dry boiling points? See paragraph S5.1.2 of this document (page 328).
