Do I Really Need These or Am I Being Scammed Again? - Page 4 - Toyota RAV4 Forums
post #31 of 37 (permalink) Old 01-04-2017, 07:06 PM
Country: BobVila's Flag is: United States
BobVila's Avatar
Originally Posted by RAVN4RED View Post
As for water being absorbed, I'm not expert (obvious by my questions, lol) but I've heard it can be absorbed slowly through the brake lines, and perhaps by occasions of extreme heat, boiling down by the calipers.
Water can't be absorbed through the brake lines since it's a closed system. In fact it's closed so well that it can regularly handle 1000-2000 PSI of brake fluid pressure and not leak out.
If brake fluid can't get out at such high pressure, I can guarantee you that nothing at atmospheric pressure can get in.
Moisture can get into the system through the brake fluid reservoir cap, which should be vented. But the vent is tiny. That in theory is where moisture can very very slowly get into the system.
But to get the system to rust from the inside out, you need oxygen. There is no oxygen in the brake system. Where does this myth of brake systems being damaged from moisture in the brake fluid come from? Probably from rust on the caliper pistons when the rubber boot fails. But that has nothing to do with changing your brake fluid.
2017 RAV4 Hybrid Limited
BobVila is offline
The Following User Says Thank You to BobVila For This Useful Post:
RAVN4RED (01-05-2017)
post #32 of 37 (permalink) Old 01-04-2017, 10:32 PM
Okay, does brake pad replacement count as a repair? I'm guessing not, so what's an example of a repair requiring bleeding. And by bleeding, does that involve replacing all the fluid in the line, or just enough to get air out of the system?
I don't bleed brakes unless I've opened the system for a caliper repair or replacement. Then sometimes I keep filling the reservoir with new fluid but often run a plastic hose from the bleeder back to the reservoir so I don't waste fluid. In any case I only do it on the needed calipers not all of them.
I wonder how many times a full brake fluid replacement service turns into a bigger repair when bleeder screws break.
Dr. Dyno is online now
post #33 of 37 (permalink) Old 01-04-2017, 10:34 PM
Country: RatRAV's Flag is: United States
This is why changing the reservoir fluid is good enough really. In fact, if you go to the dealership and pay for a brake fluid change, this is all they do: suck the fluid out of the reservoir, fill it, done.
Sent from my XT1585 using Tapatalk
RatRAV is offline
post #34 of 37 (permalink) Old 01-04-2017, 11:07 PM
That must cost about $5. Right?
post #35 of 37 (permalink) Old 01-05-2017, 09:26 AM
Not really. The moisture that enters through the cap will transfer through the system over time just from working the brake pedal. It takes about 10 minutes to bleed the brakes when you put on pads/rotors. Just do it at that time. No need for any type of special service to bleed the brakes.
joyridin' is offline
The Following User Says Thank You to joyridin' For This Useful Post:
post #36 of 37 (permalink) Old 01-05-2017, 12:47 PM
Country: RAVN4RED's Flag is: United States
RAVN4RED's Avatar
@Dr D and BobVila: Appreciate your takes on this. The reason I asked about motorcycles is because some on the FJR forums have reported getting moisture in their system and losing brakes in aggressive mountain riding as the water boils in brake line. Also notificable when brake fluid changes color, indicates moisture present. Obviously this is comparing apples to bananas, and likely the Toyota RAV brake system is better sealed than a bike.
But I have noticed the color change in the RAV's brake fluid reservoir, I'll stick to my DIY ways and swap it (rare event anyway, once every 7 years). My front pads are about due, so I'll do the full bleed at that time, as per Joyridin' post.
Now the OP is still wondering if the brake service was a scam. Sorry not much help determining that, but probably early. There is a LOT of varied opinions on this, including the difference between Toyota USA and Canada maintenance schedule. So I wouldn't sweat it.
2009 Red RAV4 Base I4 AWD
1989 Chevy Silverado V8 4WD
2004 Yamaha FJR 1300 I4 1WD
RAVN4RED is offline
post #37 of 37 (permalink) Old 01-05-2017, 02:42 PM
BobVila's Avatar
RAVN4RED, I change my fluid also because (a) I can DIY it for cheap and (b) I just find car maintenance fun.
Yet at the same time I would not recommend doing it to someone who would pay $150-200+ for it. The odds are it's better to put that money into savings.
I don't know about that. The proper procedure to change the fluid is to use a positive pressure fluid pump and to put the ABS unit into service mode to get the brake fluid moving through it too. At least that's how I've seen it done for other vehicles over the last 20 years.
BobVila is offline
