reset check engine light - Toyota RAV4 Forums
post #1 of 7 (permalink) Old 03-19-2007, 10:56 AM Thread Starter
Country: flht's Flag is: Canada
flht's Avatar
anybody can tell me,wath is the fuse I can remove for reset my check engine light,I know I can disconnect the battery but if somebody can tell me the fuse to remove,I will be do that and I will not have to reprogam my clock and radio.
Thanks flht
flht is offline
post #2 of 7 (permalink) Old 03-19-2007, 11:55 AM
Country: kikemt's Flag is: United States
kikemt's Avatar
Send a message via AIM to kikemt
annoying check engine light
well i used to have the same problem a while a go but i fix it.
my mechanic which is japanese very honest man did change sensors in my rav 4 and now since then my rav4 have more power and my light did not come back anymore.
Also y bought for like 40 bucks a scan reader from internet but still i have not use it , let's see 8)
Good luck
kikemt is offline
post #3 of 7 (permalink) Old 03-21-2007, 06:19 AM
AussieRAVer's Avatar
Looking at my Haynes manual, if you remove the EFI2 fuse (or EFI) this should reset it... Leave it out for 15 minutes and the reconnect... If the CEL comes back on, go and get the codes read.....
Keep on RAVin.....
AussieRAVer is offline
The Following User Says Thank You to AussieRAVer For This Useful Post:
Anafiel (08-15-2015)
post #4 of 7 (permalink) Old 03-26-2007, 06:50 PM
bbrendan
Could also be caused by a loose petrol cap. I had my engine light came on fora while and figured out my cap was loose.
I now have a OBDI II reader which is cool for checking what the issue is. Get one off ebay for $40. Or goto a local garage and they can check it for nicks
thanks
post #5 of 7 (permalink) Old 04-11-2007, 03:05 AM
faustas
EFI Fuse removal works!
I tried this out tonight as I also have the CEL light on.
I removed the EFI fuse for 10-15 minutes and replaced it.
The CEL light is still on when I switch the car to the "ON" position. As soon as a start the car the light goes off!
So now I can live in oblivion for a little bit (until the light comes on again...)
In the mean time, with the CEL light off, if I try check the error codes, would it return anything?
post #6 of 7 (permalink) Old 04-11-2007, 12:33 PM
Corrupt_File's Avatar
Re: EFI Fuse removal works!
All of your lights should come on when you turn the key to on, it shows you the bulbs aren't burnt out. Nothing should show up if the CEL is off, because the vehicle doesn't recognize a problem, if it did, the light would be on!
Corrupt_File is offline
post #7 of 7 (permalink) Old 04-12-2007, 06:54 AM
Not exactly - the codes get stored in a cache... it takes something like 50 start cycles to clear the cache....
Keep on RAVin.....
Saddlebag (07-19-2014)
