1997 4wd C. Diff lock not unlocking - Toyota RAV4 Forums
#1 (permalink) Old 12-21-2013, 09:55 PM
I have a 1997 4wd manual, the center diff lock has not been used in years. I engaged it while parked in neutral with engine running. Now when I hit the button it will not disengage and it beeps. I have read a few posts about this but havnt found many solutions. Is there a way to manually disengage/unlock the diff? I can hear the vacuum pressure release when pressing the button. Is there a mechanical part that sticks? I had to drive it about 15miles on the freeway with the split engaged. How much damage have I caused? It still drives smooth with no obvious damage. Please help!!
Amamotox is offline
#2 (permalink) Old 12-21-2013, 11:02 PM
Batman722's Avatar
Help! 96 Diff Problem - Rav 4 Club - Toyota Owners Club - Toyota Forum
C Diff Lock beeping and new clutch
1995 Celica - ST205 3sgte swapped
1994 Celica - Redtop Beams swapped
1998 Rav4 - winter beater - Redtop Beams swapped and actually fun to drive now.
Batman722 is offline
#3 (permalink) Old 12-22-2013, 03:24 AM
aetius757's Avatar
When my '97 beeps and does not disengage I put it in reverse and back it up 5 ft or so that always works for me. I think that is listed in the owners manual too.
Good luck
2004 (05) RAV4 4wd, 5sp "SOL" Edition
2003 Mercedes A160 (wife's)
1997 RAV4 4wd, 5sp "Woods car"
aetius757 is offline
#4 (permalink) Old 12-22-2013, 04:36 PM
Aussie50's Avatar
My little rav had the issue encountered in the second link, when they put the clutch in they inadvertently decoupled the diff lock actuator from the diff lock pin without even knowing it, thankfully they persisted and found the pin disconnected before driving anywhere.
Ed Systems - Victoria Australia
http://www.youtube.com/aussie50
Current Stable:
2000 RAV4 5dr Wagon - Name: 'Blue', 5sp Manual, Bishop Blue, Cruiser Pack - Daily Driver No1
1998 RAV4 Cabriolet, Name: 'Betty', 5Sp Manual, Cruiser Pack, Silver, - Daily Driver No2
2001 Ford Escape V6 - Name: Viki, - current repair project, backyard pet car, and future tow car.
1992 Ford EB Fairmont - Workhorse and Towing car, for when you just need a 4 liter inline six
Aussie50 is offline
#5 (permalink) Old 12-22-2013, 04:39 PM
mozz78's Avatar
If it hasn't been used much the usual problem is the sensor sticks up. Way to find out if lock is in is to jack up front of car and rotate one wheel by hand if it rotate diff lock is disengaged and sensor switch is stuck which is a barsteward because it located in the transfer box right above the steering rack and is very inaccessible with the box in car. You can stop the beeping by removing the difflock switch from the dash but you do need to jack up and check its not locked in. If it is locked in it is possible with some brute force and persistence to manually unlock it by removing the o/s wheel locating the rod that runs into the transfer box and disengaging it. My opinion...... You wanna hope its the sensor that's faulty cos anything else is a pig of a job. Good luck and keep us posted :-)
mozz78 is offline
