Hi.
First I want to thank everybody on this great forum. It has helped me a lot. :smile
I have just bought a Rav4.1, and I am experiencing some problems with the ABS-system. When I am breaking on dry roads at low speeds, the ABS kicks in.
The ABS-bulb in the dashboard is working, but it is not on when driving.
I have run some tests with jumpers in the DLC1 underneath the hood. But I am not sure if I am doing this right, because I got all the error codes from the blinking bulb: 71, 72, 73, 74, 75, 76, 77 and 78. Error codes on page 7(149) in this PDF
I also get error code 79, but it is not in the PDF. I think it is strange that all the speed sensors has errors, so I suspect a broken ECU.
But before I try to replace the ECU, I want to replace the ABS-rings/Tone-rings/Reluctor-rings and clean the speed sensors. Maybe they are just full of dirt and rust.
I want to buy the ABS-rings before I start taking things apart. So I am wondering if someone knows the inner diameter of the ABS-rings that fits front and rear on my car?
I have found two types on eBay, 70mm and 80mm, both with 48 teeth. I have also been at a local Toyota dealer, and they told me that they did not sell these rings. They wanted me to buy new axles with rings, but that is too expensive for me.
Some information about the car:
Rav4.1 SXA11L-AWMGKW
4x4 5-door
Year: 1998/1999
Engine: 3SFE 1998cm3
Driving length: 150000km (93200miles)
Manual gear
Bought in Europe (Norway)
~Liloolil
4x4 5-door
Year: 1998/1999
Manual gear
~Liloolil
