Rav 4 died will not start up [solved!] - Toyota RAV4 Forums
post #1 of 52 (permalink) Old 12-14-2009, 08:07 PM Thread Starter
Hey everyone,, newbie here,, this is my first Toyota & what a let down LOL The day i bought it and drove it home , it worked good, than went to town and it just died,, bogged out just like it ran out of gas(has 1/2 a tank tho),,,, had to get it towed home, it kicks every so often and that it,, so can n e one point me to what may have cause this,,
[EDIT: Solved http://rav4world.com/forums/viewtopi...=239650#239650 ]
firsttoyota97rav4 is offline
post #2 of 52 (permalink) Old 12-14-2009, 10:25 PM
2001SL2's Avatar
Sorry to hear that. Don't give up or get discouraged. Mine has 247,000 miles and it still runs VERY strong and reliable.
Welcome to the forum, this is what we're hear for
First: Check the battery terminals. Make sure posts are clean and terminals are tight.
Second: Make sure when you put the key in the Run position before starting the engine you hear a light buzz from under the car for about 1 or 2 seconds. That's the fuel pump priming. If it ever DOES NOT do that, then the pump is kicking the bucket. Replacing it is very simple.
Third: Make sure spark plug wires are well attached and pushed in.
I would start by checking those three things. Those would be the most basic and important to getting the engine starting properly.
Kurt
2001SL2 is offline
post #3 of 52 (permalink) Old 12-15-2009, 03:13 AM
mensajero's Avatar
Welcome to the forum. If you don't have the tools or the know how. Get a scanner from your local Pep Boy and plug it into your RAV4. Here you can get all the information you'll need regarding this procedure.
Once you know the code, look it up on the net. Scanners also bring a booklet or a CD ROM with the information you will need. Once you know the code, your home free. It will pin point the problem.
BTW, doing what 2001SL2 says IS a very good alternative. The man knows his stuff.
mensajero is offline
post #4 of 52 (permalink) Old 12-15-2009, 07:31 AM Thread Starter
yaa i went out and turned the key on, and i dont here no buzz ,,, than i got a friends OBD reader and all that came up was PO141 ,,which i founds was Oxygen heater sensor 1 bank 2 ????
post #5 of 52 (permalink) Old 12-15-2009, 01:11 PM
a p0141 will not cause a no start. The first things you should look for with a no start is Fuel, Spark, and Compression
Fuel?
Spark?
Compression. it ran before, did the temperature change drastically? I would say leave it till last. I think it is more a spark or fuel problem.
Looking at the p0141 electrical circuit the heater and the fuel pump share the same power source point coming off the EFI relay...
I would check to see if the pump is getting power as step one.
calgaryrav4 is offline
post #6 of 52 (permalink) Old 12-15-2009, 04:52 PM
mensajero's Avatar
Yeah, sounds like fuel delivery. How is the Temp in your area?
post #7 of 52 (permalink) Old 12-15-2009, 05:01 PM
tinmanchris217's Avatar
Send a message via AIM to tinmanchris217
Sorry to hear the dealership sold you a car with "baggage." Once you get this issue (and possibly the O2 sensor) fixed, it should be a very reliable little car.
My 2 cents,
This reeks of fuel pump failure. As 2001SL stated, listen for the hum of the fuel pump. It won't be loud, but it's the only thing making noise back there. Either stick your head next to the rear tire, or press your ear on the trunk's carpet.
If this is the issue, be sure to install a new fuel filter too. Preventative maintenance.
If fuel pump is working, look towards the ignition system. Could be a grounding spark plug wire, or failing ignitor (coil). Most shops can diagnose this using a multimeter or intentionally short-circuiting each wire.
tinmanchris217 is offline
post #8 of 52 (permalink) Old 12-15-2009, 05:24 PM Thread Starter
Hey guys,, i took the back seat out and cover off to the fuel pump,, there was 2 wires ,, Red & black and there is NO power going into the pump,,, soo where does the fuel pump get its power fr ????
ohh tinmanchris217 i bought it used off kijiji not a dealer,,
post #9 of 52 (permalink) Old 12-15-2009, 05:29 PM
Fuel pump should get power when car is "ON" and during "START". Voltmeter should show 12V if the car is "ON"
If it's not, check fuses. That's way easier than replacing the pump.
post #10 of 52 (permalink) Old 12-15-2009, 05:35 PM Thread Starter
Hey yaa with the Key ON & or START theres nothing,,, checked all the fuses, they were good,,
