Hi,
I need to identify a part located near the engine. Someone told me I should replace it to reduce pollution. Can anybody help? What is it exactly? Does a replacement of such part could help in reducing pollution? It's for an '96 automatic petrol rav4. Thanks. [img]/forums/album_pic.php?pic_id=10175[/img] [img]/forums/album_pic.php?pic_id=10176[/img] |
I believe that is the MAP sensor, but I am not sure.
Kurt Bored throttle body, Ram Air Intake, 2.5" dia. exhaust, DynoMax muffler, Thrush resonator, 9005 low beams... + more |
Country: Join Date: Jan 1997
Feedback Score: 1 reviews
You guys are correct, it IS the MAP.
http://www.cardomain.com/ride/400637 |
The sensor measures the changes in pressure (MAP=Mass Air Pressure) in the intake manifold and adjusts the amount of fuel injected accordingly
High pressure = low vacuum = WIde Open throttle Low pressure = high vacuum = Closed throttle Throttle plate partially open + high vacuum = engine under load etc It is essential for adjusting the fuel mixture and timing
#8 (permalink) | |
Did you fail an emissions test recently? |
#9 (permalink) |
Well, the emission test didn't failed but is really poor.
We tried to disconnect the sensor few seconds during the test and emission went better... I think It may add too many fuel in the mixture adjustment. The guy at the emission test told me he has already seen that before with another kind of car and the replacement of such sensor had resolved the problem. The car has been checked by Toyota very recently for some parts replacement and engine check (among other little things). They didn't find unusual things. |
