Boyfriend put battery in backwards...HELP! - Toyota RAV4 Forums
post #1 of 17 (permalink) Old 01-13-2011, 11:29 AM Thread Starter
We have a 98 toyota rav4, standard. My boyfriend put the battery in backwards one day. When he did that all of the instruments shut down. Nothing worked except the headlights, and the car DID run. Until the next day. He went to his brothers house, then had to get him to jump it off. He drove to our house, almost got there and the batt. died. which means alternator. I Know i need a new alt. but what else? I dont want to replace that, and have it go out again. Is it the computer, a wire? All of the fuses are still good. Any advise would be great!
DUKE
duke8780 is offline
post #2 of 17 (permalink) Old 01-13-2011, 12:15 PM
hd72m's Avatar
Did he put it in or hook it up backwards?
Why did you need new battery?
I think alternator or dirty,corroided battery wires or connectors was bad to start with.
People over look under coating of red battery wire,slice coating 3 inches on the side and look for green crud and clean or replace. If you clean tape up wire when done.
The second cables are hooked up backwards it will blow a fuse or blow up battery.
hd72m is offline
post #3 of 17 (permalink) Old 01-13-2011, 12:58 PM
Country: ecuadorche's Flag is: United States
its probably a fuse, i guess
ecuadorche is offline
post #4 of 17 (permalink) Old 01-19-2011, 06:14 PM Thread Starter
Both, We were going to take the boat out, and needed the battary for the motor. He was checking the other spar ones that we had, and accidently put one in backwards, hooked up and all. Its not a fuse, or relay. all those were checked. and its all clean.
DUKE
duke8780 is offline
post #5 of 17 (permalink) Old 01-19-2011, 07:08 PM
hd72m's Avatar
If it was hooked up backwards it would either blow up battery or blow fuse and it would not run.
Find or buy a ohm meter,$20 or less and start it up and check volts at the battery when idling and then speed up motor while checking voltage.
When motor is reving it should read at least 13.5 volts,if not and you are SURE connections and wire under red coating is clean then alt is bad.
Again it would not start with battery hooked up backwards.
hd72m is offline
post #6 of 17 (permalink) Old 01-19-2011, 08:16 PM
Fuse.
ttaylor05 is offline
post #7 of 17 (permalink) Old 01-20-2011, 06:03 AM
Country: RAVMAN's Flag is: United States
RAVMAN's Avatar
Originally Posted by ttaylor05
Fuse.
Been there... done that It's the BIG fuse by the battery
Retired from R4W CLICK HERE
RAVMAN is offline
post #8 of 17 (permalink) Old 01-20-2011, 08:49 AM
Originally Posted by RAVMAN
Fuse.
lol me too except i done it with booster cables :P
Fuse is actually bolted down i believe so be careful to not just rip it out...
post #9 of 17 (permalink) Old 01-20-2011, 09:35 AM
hd72m's Avatar
"Been there... done that It's the BIG fuse by the battery"
Will it still run with fuse blown?
" Nothing worked except the headlights, and the car DID run."
hd72m is offline
post #10 of 17 (permalink) Old 01-20-2011, 01:20 PM
Oh btw Ur alt is fine you do not need a new one. Just replace the fuse and boost the battery and ur good to go.
