Country: Join Date: Jan 2010
The rear differential on my father-in-laws 1998 RAV4 just locked up the other day making the rear tires skid the car to a stop!
![]() A replacement differential may be available from a forum member in a few weeks. It was towed to a garage so I haven't looked at it yet but I'm wondering how easy or difficult it would be to temporarily convert it to front wheel drive. Obviously you'd remove the driveshaft but I'm not sure what you'd need to do with the axle shafts. Anyone know?
Country: Join Date: Oct 2010
Don't forget the center differential, torque spread, ABS, mapping and so on.
I am not a mechanic, but i doubt it can be done for a short while and for a reasonable price. Greetz Pim
Country: Join Date: Jun 2010
If you remove the driveshaft/propshaft the only way you will get drive is to lock the centre diff and I think this restricts the speed you can travel at, doesn't it???
I have never driven above about 30 with it locked so can't say for sure, The short answer to the question is NO.....sorry! |
#4 (permalink) | |
So does the center differential stay locked manually like my F-250s or unlock itself like my '06 RAV4?
Country: Join Date: Nov 2008
This guy removed the drive shaft on his 2011 and drove it as a FWD for several days. No problems and no error lights:
Help Removing REAR DRIVE SHAFT
#6 (permalink) | |
I'm trying to find out how you lock the center differential on a 4.1 automatic. Guess I should have looked at the owner's manual when I was there today. The mechanic had to disconnect the driveshaft and one of the axles to get it to roll at all. |
Sorry Fred, didn't realise it is an auto, all I know is the manual has a diff lock button that manually locks the diff, I think the auto does it differently but I don't know how....
#8 (permalink) | |
Anyway I just looked at the car and got my answer. I could not find any lock lever or button. Automatics apparently don't have a lock option like manual transmissions do. So w/o that it would likely be too much stress on the transmission to run it w/o the rear driveshaft operational. |
#9 (permalink) |
The automatic use pressure plates and a torque converter wheel to distribute the torque between front and back evenly in case of bad road surface.
It's tough to unlock that and fit it into place as far as i saw in the repair manual. Greetz Pim
#10 (permalink) |
Just to wrap this up; I bought a used rear differential from a yard, put it in and it's all better. It was a failure I'd never heard of before. The bearing on pinion (input) shaft just locked up solid ... and it had plenty of oil!
