Help: Bilstein Rear Shocks - Help Me Install Correctly (Thun-thunks over bumpy roads) - Toyota RAV4 Forums : RAV4World.com
Old 11-30-2012, 06:39 PM   #1 (permalink)
Default Help: Bilstein Rear Shocks - Help Me Install Correctly (Thun-thunks over bumpy roads)
1999 Rav4 L 2WD 4-door
I purchased Bilstein Shocks for the rear of my car through Autozone.
Part: 24021203
Alt. Part No.: F4-B36-2120-H0
I don't believe I installed my Bilstein shocks correctly. The instructions were vague. I followed Bilstein's recommendation of following the original assembly order that my Toyota had with the original shocks. I also used some of the Toyota parts instead of the Bilstein parts. Here's the photo of the order that I used:
Could someone help me with this? What order did you place the gaskets and rubber cushions? ALSO: How did you keep the screw from turning while screwing on the last nut? Pictures would be helpful. Thanks!
meandiet is offline   Reply With Quote
Old 11-30-2012, 07:48 PM   #2 (permalink)
Batman722's Avatar
Feedback Score: 1 reviews
Put the rubber under the body also.
The rubber goes above and below the toyota body and acts as a cushion, no more bumpy bump.
1995 Celica - ST205 3sgte swapped
1994 Celica - Redtop Beams swapped
1998 Rav4 - winter beater - Redtop Beams swapped and actually fun to drive now.
Batman722 is offline   Reply With Quote
Old 12-01-2012, 12:41 AM   #3 (permalink)
mensajero's Avatar
Batman is right. If not, the squeaky or thumping noise will drive you crazy.
Old 12-01-2012, 01:14 AM   #4 (permalink)
See if you can stick a 6mm Allen wrench into the top of the rod.
Carbon is online now   Reply With Quote
Old 12-01-2012, 04:54 PM   #5 (permalink)
Does this order look better? Rubber cushion and the gasket to keep it in place added below the car's body.
Thank you, Carbon, for the allen wrench tip. I checked that and it will work beautifully!
