#51 (permalink) | |
Country: Join Date: Aug 2007
. Fred, you have always been a "big man" in my eyes, but if you are able to hang upside down and work on that junction box, 4" in front of your nose, I'm now picturing you about 4'0" tall, 98 lbs, and spineless. ![]() I can't say I remember it being that much fun the last time I tried to get my 6'4", 230 lbs back out from under the dash. Thought I might have to call the fire department.
#52 (permalink) | |
Country: Join Date: Jan 2010
![]() And, altho I haven't been following this thread blow by blow, I can't help but think it's something simple. Obviously the lights have to get power and ground which I'm sure you've covered, but short of a lot of smoke and melted wire or a simple pin pushed out at a connector I can't imagine any other failure mode. I'm afraid smoke and more damage is what may happen with cutting, splicing and bypassing. I'd love to get my hands and my filament-bulb 12V test light on it. I wouldn't even trust my meter or my LED 12V test light since they don't give a load the would find a weak connection. I the meantime let the saga continue BTW, don't tell Joe, but I might even buy at Wendy's just for the fun of troubleshooting his RAV. |
#53 (permalink) | |
Joe did use both a test light and multimeter at various times, which required additional testing be done to eliminate the possible misinterpretation of results, but I think in the end we narrowed it down to the bad connection in the junction box. If you get some time to read over the thread, I think Joe and I would both value your opinion. Don't worry I won't mention a word to Joe that you will buy lunch AND fix his light problem. I may take you up on the offer though the next time I need to crawl under the dash. I think the 9 hour drive is more favourable than crawiling under that dash again.
#54 (permalink) |
Country: |
I think I owe you both lunch at Wendy's, plus some beers. DD, I'll bet you'd probably spend 5 minutes in our Rav and have the problem solved. In the end, I wouldn't be surprised if the real problem is something really easy to fix, like the accessory tip in the cigarette lighter was for the radio short.
If I knew which connector to disconnect while getting upside down and contorting my fingers I'd probably go for it. I have fresh memories this year of crimping a wire and causing a short that ruined the optical drive in my Mac while struggling to install it in it's bay. Consequences of damaging something unrelated to the personal lights are enough to scare me from trying. Tomorrow I'm going to see if it would be easy enough to put fuse taps in the actual DOME fuse in the box to the right of the engine and wire up to the BLU/YELs in the windshield column. If I'm able to confirm the BLU/YELs as Rick described, and snake the wires through (I'm assuming I should do two wires, one for each BLU/YEL so the load is correct?), I'll go for it. |
#55 (permalink) | |
Making the temporary test connection means no fishing wires either until you know it will be worth your while. All the work can be done without leaving the drivers seat.
#56 (permalink) | |
#57 (permalink) |
Also, if you are not familiar with fuse taps (and there are many styles and sizes), make sure you connect the "tap" to the load side of the fuse and not the supply side.
#59 (permalink) |
Country: |
I thought I had an 'aha' moment yesterday and that my next post would be one of triumph. Sadly, it isn't
Finally, when I disconnected the harness, I did in fact see signs of corrosion on the individual connectors. I figured that just had to be it. I sprayed it real good with the cleaner (but did not phyiscally clean the connectors yet as I didn't have anything to fit into the little square holes to clean with). I waited a couple of hours for the cleaner to completely dry, reconnected the harness, then the battery. Nothing I didn't yet attempt any part of the hack (nor did I do the BLU/YEL confirmation test yet). When I opened the hood I didn't see any easily reachable grommet that I could feed a wire through. The ones that were easily reachable and visible were pretty tightly in place and I don't know if they come out on the inside of the firewall in a place I can reach. Any thoughts on that connector or wiring if the hack is still the way to go? DD, scheduling that trip out to Wendy's is starting to look very appealing
#60 (permalink) |
Hey, if you found any corrosion that's progress! And you have the connector in hand. I'd try hooking the battery back up (yes that's safe) and turning the lights on. Then watch them as you connect/disconnect those plugs. If the lights do anything you've localized it and only have to physically clean the pins. That can be done by removing them from the sockets or you could run a bypass wire around them right there.
BTW, what's the pink snap-on connector on the left side of your picture? FYI, those electrical sprays sometimes work for low power electronic circuits but not often for circuits carrying almost an amp. |
