oil pump housing - Toyota RAV4 Forums : RAV4World.com
Old 01-01-2013, 10:46 AM   #1 (permalink)
Default oil pump housing
can somebody give me instruction on a fix?
i finally pinpointed the source of the slow oil leak, which occurs during warmups.
Old 01-01-2013, 01:11 PM   #2 (permalink)
resending for replies.
Old 01-01-2013, 06:12 PM   #3 (permalink)
sender resending.
Old 01-01-2013, 10:34 PM   #4 (permalink)
anybody?
Old 01-02-2013, 12:04 AM   #5 (permalink)
sheesh
Old 01-02-2013, 12:12 AM   #6 (permalink)
hd72m's Avatar
Sorry I cannot help you,never been around the oil pump.
Old 01-02-2013, 12:33 AM   #7 (permalink)
thank you for the reply.
i have my own way for the fix.
but i was hoping to get better, perhaps time saving techniques.
thanks anyway.
Old 01-12-2013, 04:59 AM   #8 (permalink)
whats is wrong with the oil pump. i had a leak which i thought was the sump gasket but it was a o ring on the oil pump housing which had gone. if its the same then its set timing, loosen timing belt. remove the other belts too. remove crank pully remove lower belt cover. remover oil pump, change oring which is a wierd shape then then tighten bolts back at 8Nm i think it was so it doesnt crush the new o ring. then put it all back.
mrbilly is offline   Reply With Quote
The Following User Says Thank You to mrbilly For This Useful Post:
4x4 rav (01-12-2013)
Old 01-12-2013, 05:27 AM   #9 (permalink)
hello mrbilly!
what a coincidence! i was working on this project a short while ago. i'm taking a break now.
you wrote: "if its the same then its set timing". what did you mean?
from my observation, i also concluded it was the O-ring inside the oil pump. but i bought the housing, which include the pump, the crank seal, all installed. i didn't want to take a chance by just replacing the O-ring, in case there are other issues with the housing.
sincerely
Old 01-13-2013, 05:49 PM   #10 (permalink)
i mean set the timing of the engine before working on it, set cylinder 1 to tdc. then take it all apart. look on youtube for 3sfe oil leak it maybe helpful. mine is now leak free
