ignition timming?? - Toyota RAV4 Forums : RAV4World.com
Old 01-02-2013, 04:21 PM   #1 (permalink)
Country: 97Rav 4's Flag is: United States
97Rav 4's Avatar
Smile ignition timming??
I purchased a 1997 rav4 auto awd (150k) since I've had it it's been avg. 18-19mpg 60% freeway,I changed the vsv,left front wheel bearing,cleaned the throttle body,and idle control(took them of the motor)bought a k&n,replaced the autolites with NGK laser cut plugs,cap and rotor,fuel filter and a had my transmission rebuilt($1500 not bad included R and R) cause it leaked out of the bell housing(Rav has 150 k on it)it still seems to get the same mpg when I bought it(2 months ago) the guy said he change the distributer O ring, is it possible the timing is off(it runs great just gets poor millage,do I need to reset the computer after the plugs,cap and rotor.I reset it after the vsv(which I moved to the firewall for the next time! ) then did plugs.After the plug change it starts up right when I turn the key,before it would turn over 2 or 3 times but my wife says it still seems the same mpg wise,(after 2 days)90 miles . To reset the puter I just unplug the battery for 1/2 hr. right?
Any help would be appreciated Thanks
97Rav 4 is offline   Reply With Quote
Old 01-02-2013, 11:46 PM   #2 (permalink)
hd72m's Avatar
Yes unplug battery will reset it but you have to drive it for a bit.
Timing cannot be changed unless computer of sensors do it.
I would check wheel hubs to be sure brakes are not dragging,when you stop feel for extra heat. Do this after hwy miles and around town driving and remember brake hoses can be starting to collapse which would make them stick for a short time every time you use the brakes. This is a stretch but just throwing ideas out there.
You should never put more gas in after pump kicks off because it can ruin charcoal canister and if you do this I do not see how you can be sure on mileage with just driving 90 mi so you might want to give it more time.
Take any extra weight out and keep tires up.
The Following User Says Thank You to hd72m For This Useful Post:
97Rav 4 (01-04-2013)
Old 01-03-2013, 06:42 AM   #3 (permalink)
97Rav 4's Avatar
I will try it , thanks for the response!
Old 01-03-2013, 03:50 PM   #4 (permalink)
97Rav 4's Avatar
What about initial set up,,can the gear be of one tooth or housing turned slightly,I think it has a slot in it for the hold down bolt?Or would it not run
Old 01-03-2013, 04:30 PM   #5 (permalink)
Country: Meander's Flag is: Canada
Some more ideas ;
1 Spark plug wires - with old ones the resistance increases causing poor
spark
2 Dirty air filter -poor air fuel mixture
3 Dirty fuel filter- see above
4 Poor wheel alignment- more drag
5 Low tire air pressure- see above
6 Driving style
7 Driving distance- my 2012 has lower fe than posted because among
others we take 2-3 km trips.
8 Weather-in cold weather it takes engine longer to get up to right temperature
9 Tires- aggressive tread or different than factory tire size
Good lack tracing your problem.
Meander is offline   Reply With Quote
The Following User Says Thank You to Meander For This Useful Post:
Old 01-04-2013, 08:16 AM   #6 (permalink)
97Rav 4's Avatar
thanks,I havent changed the wires yet
Old 01-04-2013, 10:38 AM   #7 (permalink)
hd72m's Avatar
Do not use bosh wires, a lot of us have had trouble with them.
Old 01-04-2013, 10:45 AM   #8 (permalink)
R4W Moderator
DJ Sueno's Avatar
Feedback Score: 1 reviews
Distributor is in a fixed position and cannot be adjusted... At least when I changed the oring on my 96 I noticed that it wasn't adjustable. The 97 should be the same...
DJ Sueno is offline   Reply With Quote
The Following User Says Thank You to DJ Sueno For This Useful Post:
