Country: Join Date: Oct 2012
Hi All,
Before I start, I have been through just about every idle related thread on all Rav4 Forums I can find. So here it goes :- Car : 1997 (april) Rav4 (of course), 4 Cylinder, Auto, 4/5 door Location : Melbourne, Australia Other Info : -
Here are my steps I have used for diagnosis so far, except of course for the checks above :-
![]() Has anyone any ideas before I take it into a garage and hope they can find it ? Hope someone can help, this is my daughters learners car and its not a good experience stalling on busy intersections and not being able to restart Andy |
Country: Join Date: Jun 2010
You should have OBD1, have you tried reading for codes by jumping T and E1 in the diagnostic socket? Not all the sensors throw the CEL but will record a code.
More info can be found here Automotive Training and Resource Site (tech articles) Is the click from the IACV or the TPS which will click when the throttle is closed? The ECT (two wires) is very cheap to change it may be suspect, could be responsible for wrong signal to ECU causing it to pink ECT easy to check if you dont want to change, if you have a multimeter, just look for change in resistance as it warms up (or not). Could it be the O2 sensor? is it cutting out when it changes from open to closed loop? That said, it will run without the O2 so probably not. Good luck. |
#3 (permalink) | |
I will certainly have a read at that site, looks interesting. I am sure its the IACV as the throttle is fully closed (and I am under bonnet) when it clicks I suspect it may be temp sensor, I will warm it up with a multimeter attached, when good record reading, record reading when bad, if different I may just try diagnosing by replacing with a resistor of equal value to the good value. see if problems go away. The ECU appears smart enough to know when this one is out of range and thow the CEL on. Worth a quick check I suppose As this happens when car has warmed up, even when not moving, I don't suspect the TPS as it has to be well warmed, not just warm. If you follow my logic there. I should have some freezer spray somwhere, so may blast it to confirm when problem happens o2 as you say shouldn't cause such a dramatic failure I will find a paperclip and look for codes. Thanks Andy |
Ok, was Showing code 22 (Engine Coolant Temperature Sensor signal)
Which was because I disconnected it, I reset and retried and it went away So, I chucked my multimeter on the ECT, looked ok at first, then went from about 600 ohms out of range, so I changed range.. Was floating around 196K. Have a feeling the pins may be dodgy on it too. 600ohms looks about right for the 20c ambient here From what I found online it shows 20k at -20c, dropping to about 0.5k at about 70-80c (probably thermostat range) I found a 1k resistor, which is about 40c on the chart, the engine wasn't fully warmed when it cut out, probably 1/4 of gauge, added this, engine ran steady as a rock, once in correct temp range I could tell it was a little rich running from exhaust, but was still steady Guess its off for a new temp sensor tomorrow (and a deep socket to fit it, I have read its a 19mm, but will test in shop) Thanks for the help Andy |
Great news, allways good to hear what the problem actually was, the ECT is probably the cheapest fix in your situation too. You don't need a socket a ring spanner will suffice, a bit harder to get at I agree, I think I used a 19mm ring.
Save that autoshop101 link in your favourites, it may come in handy again! Ken |
Picked up a new sensor, genuine toyota from a dealer $97, lot cheaper for OEM in UK and US, however good news is that it is fixed now!
(I found my deep sockets in garage too) Thanks for the help |
