12V Battery replacement! - Toyota RAV4 Forums
post #1 of 7 (permalink) Old 12-06-2011, 04:24 PM Thread Starter
Hi all, I have a 2004 2.0 Rav4 XT4 Diesel D4D, Exactly what type of battery should this have? My present battery is taking about 3 turns of the key to start the engine, I think it has been on from new about 7 years so must be due a change! Also how do you remove the battery from its compartment (under the cover) I know the sequence of lead removal!
Do you lose any radio codes...etc? Do you have to inject 12v from another source whikle the battery is removed?
I have the user manual plus a Haynes but both are very vague in this area!
Regards, Steve (UK)
sniper9652 is offline
post #2 of 7 (permalink) Old 12-06-2011, 04:45 PM
Country: 03rav4inPA's Flag is: United States
03rav4inPA's Avatar
Pretty sure yours is the same as mine, use a coin to remove the plastic tabs on top of the shield(near the wipers). Once off, you have full access to the battery.
2003 Toyota Rav4 -- 2.0 VVT-I/Auto/4WD, 132k
Current Mods: Bugflector, AVS Ventvisors, Eclipse AVN30D, OEM Foglights, OEM Heated Mirrors
03rav4inPA is offline
post #3 of 7 (permalink) Old 12-06-2011, 06:49 PM
rns
Country: rns's Flag is: Finland
rns's Avatar
If you can use some small battery loader to keep up the volts, there is no harm of it. Then you won't loose either any codes, clocks etc.
I guess you can find with around 30 GBP nice loader that can be useful otherwise too.
http://www.ctekchargers.co.uk/
But to my knowledge, problems caused by sudden ampere peak when putting new battery on, are more often in German cars of starting of this age.
2003 Corolla had no problem when I swamped battery old style.
rns is offline
post #4 of 7 (permalink) Old 12-07-2011, 06:42 AM
Country: Joylove's Flag is: United States
Radio is not coded, but you might loses the clock and the engine adaptations, leading to a lumpy idle for the first 80-100 miles.
The best place to buy batteries is Vauxhal main dealer, they are rebranded AC Delco premiums. You want the reverse terminal (positive at the front left), a 70aH is ~Ł96 inc the VAT. My local place does not have this arrangement in stock but it arrived next day.
If you don't get a reverse terminal, this is what happens, the +ve is in the wrong place (rear left) and the +ve cable is just a little too short to be comfortable. The cables are stretched and very hard to fit, and the red cover no longer fits also.
I've now changed this battery.
Joylove is offline
post #5 of 7 (permalink) Old 12-08-2011, 02:13 PM Thread Starter
Thanks for the photo's and info! What are 'engine adaptations'? Did you get a "lumpy idle" when you changed yours?
My 54 plate Rav is the diesel engine, I needed four cranks with the key this morning so I think it may be time to change the battery soon! Does anyone know the name of the original battery that was supplied with these cars when new cos I think that one is still on after 7 years!!
Steve
post #6 of 7 (permalink) Old 12-08-2011, 02:59 PM
Probably a Yuasa. Also good batteries.
Engine adaptations are the things the engine ECU learns about how your engine components age and it attempts to compensate for them. Yes mine is lumpy for the first 100 miles (I pull the battery a lot for my DIYs), it's a petrol.
Joylove is offline
post #7 of 7 (permalink) Old 11-14-2012, 05:09 AM
Country: earthrealm's Flag is: Nigeria
earthrealm's Avatar
Send a message via Yahoo to earthrealm
buy a battery with good/high cca . from 600cca upwards is good
2005 4runner auto sr5 4wd v6 galactic gray.
2003 rav4 auto I4 4wd titanuim silver
earthrealm is offline
