| 4.2 General Discuss anything RAV4.2 related that doesn't fit in the categories below. |
Country: Join Date: Dec 2011
i filled my 2005 2.4L rav which has 56 L gas tank to full; drove typically mixed city/highway and got 330 km's before it was near empty and the gas light came on. this is in canada. thats not very good is it (94k km's on it)
Country: Join Date: Sep 2011
so that's about 205 miles for 14.7 gallons...wow something is pretty off. I know that wintertime = worse gas mileage, but I think you've got bigger problems.
When's the last time you: changed oil changed air filter cleaned out your throttlebody checked your tire pressure
2003 Toyota Rav4 -- 2.0 VVT-I/Auto/4WD, 72k Current Mods: Bugflector, AVS Ventvisors, Eclipse AVN30D, OEM Foglights, OEM Heated Mirrors Future Mods: OEM rear-spoiler, OEM 'Sport' hood |
Wouldn't 02 sensors throw a code if they were fouled?
just had oil changed and tires seem fine; i just bought the car; perhaps throttle body never been touched; next wk i will do a tune up;
Tune up should help, but also check to see that your brake pads aren't locked down. That friction drag will destroy your gas mileage.
2003 Rav4 L: Feidie UFO projectors + HID, TTE grille, Weapon R intake w/ AEM filter, Tanabe exhaust, LED turn & tail lights, Clarion MAX675vd 7" deck, Alpine amp, Alpine Type-R component & composite speakers, Rear 7" screen for the kid |
Country: Join Date: Oct 2011
That's strange.
Usually when I have a full 45L tank I can go 400Km city driving. I was thinking that if you meant "gas" as in LPG, it'd make sense because they run out faster...but this is probably not the case. I've heard cases where if the cat converter is dead/dying it affects the MPG. |
#8 (permalink) |
the brake pads are not locked down; i let go of the brakes and the car eagerly goes foreward.
today i put in a new air filter and iridium spark plugs. hopefully that will help. cheers |
#9 (permalink) |
check your tire pressure
also, pick a bottle of this stuff up at any cheveron, its about 10 or 11.99 a bottle and let me tell you, it WORKS wait until empty, pour this stuff in and you may as well fill up with 94 octane at chevron drive till empty as this wil clean you fuel injectors out after 2-3 tanks you should be hittin high 300's-low 400km's a tank
Im buff |
