| 4.2 General Discuss anything RAV4.2 related that doesn't fit in the categories below. |
Country: Join Date: Jan 2013
Hi all ,, first post so hopefully in the right place
Thought id pop in here and ask if theres any gotchas i should be aware of when fitting front disks and pads to a 2004 rav ? Im helping out a neighbour whose just been widowed suddenly as. Her brakes are on the metal and she doesnt have a lot of money so i offered to help I own a landy so have tools and some experience etc Hopefully theres nothing out the ordinary on a rav with a disk and pad change but thought it wise to ask first as some vehicles these days have odd dos and donts ,, ie shogun di-d you dont squeeze the brakepistons back in without releasing the bleed or the back pressure of fluid can fault the abs system. Looking forward to hearing if its straightforward or not as im probably doing it for her tomorrow Any help or tips much appreciated nick |
Country: Join Date: Jan 2009
You will want to search out what grease to use and where to put it.
You are already ahead of many with your plans for the brake fluid bleeder and the can of brake fluid.
2009 V6 4wd Base |
Country: Join Date: Apr 2008
There is a thread here in the 4.2 forums with the factory service manual available for down load. But the only posts on here with problems changing brake pads all involve corrosion. When badly corroded this job will turn into a nightmare.
On the road in my Rav4 since February, Traveling, Volunteering, Camping and also enjoying beer bikes and bacon. Check out the blog www.servicedriven.org |
Ok thankyou , which bits are problematic ? Carrier bolts im guessing
Is the disk held on with one of those countersunk screws ? Ill go have a look for the download |
Country: Join Date: Sep 2011
Nothing out of the ordinary, these brakes are pretty easy to replace.
2003 Toyota Rav4 -- 2.0 VVT-I/Auto/4WD, 87k Current Mods: Bugflector, AVS Ventvisors, Eclipse AVN30D, OEM Foglights, OEM Heated Mirrors Future Mods: OEM rear-spoiler, OEM 'Sport' hood |
I think the disk is held on by the lug nuts+bolts and probably rust.
The 4.3 disks have one or two M8 x 1.25 threaded holes that can be used to help force off the disk by inserting a screw to push out the disk. I don't know if the 4.2s have the same, but I would suspect they might. This looks like a really good method, and it does not involve getting screws into thread that may be rusted. It shows a Ford, but the technique should be generally applicable to RAV4s too.
2009 V6 4wd Base |
| The Following User Says Thank You to Carbon For This Useful Post: | Scotty61 (01-29-2013) |
I got mine off with heavy hammer ok the vibration sprang mine off el rapido, they are only press on and centered on the wheel nuts
Warning Warning Warning (As per the lost in space Robot) wall |
