Hi all I know im here in the UK but thought you guy may be able to help.
The 2002 Rav was running fine when it was switched off but then to day the speedo is either not working or bouncing so I had a look at the sensor and cleaned the contacts no joy so it may well have gone but there are other strange things would the sensor cause the gears to be in and out and the clutch appear to slip? Before I spend out on the sensor and find out its an ecu problem.
Thanks in advance
Thanks in advance
