Backup (reverse) lights stopped working overnight--why? - Toyota RAV4 Forums
post #1 of 8 (permalink) Old 08-22-2006, 03:48 AM Thread Starter
Liz
Liz's Avatar
Up until just a couple days ago, my RAV's white backup lights always worked. Then on Sunday evening, they were dark, and they still haven't worked since then. Got any ideas why? All the other lights and indicators outside and inside the car still work.
2001 2WD 5spd QO moonroof, >210k miles
Liz is offline
post #2 of 8 (permalink) Old 08-22-2006, 10:01 AM
AussieRAVer's Avatar
Checked the globes??
IF they are ok, wiring connectors??
Fuses??
Reverse switch on gearbox......
AussieRAVer is offline
post #3 of 8 (permalink) Old 08-22-2006, 11:49 AM
Country: garfieldgurl's Flag is: United States
garfieldgurl's Avatar
Could it be burnt lightbulbs
Miriam
Love your Rav
garfieldgurl is offline
post #4 of 8 (permalink) Old 08-24-2006, 03:55 AM Thread Starter
Liz
Liz's Avatar
Well, I doubt that both bulbs/globes died at the same time overnight. They both worked fine on Friday and Saturday.
I did check the fuse, and it looks fine.
I haven't figured out where the switch is. A coworker who works on his own cars (including a Camry) helped poke around in the engine near the starter motor this evening, and nothing looked like the right part.
Does anyone out there have the Toyota manual? Where is the switch, and what do I have to do to test it?
If I don't figure it out in the next day or so, I'm going to stop by the dealership and have them take a look.
Liz is offline
post #5 of 8 (permalink) Old 08-24-2006, 08:33 AM
You would be suprised!!! I change one headlight globe on my other car and within minutes the other bulb went out.........
I'm guessing (Coz I dont have a manual yet) that the switch is on the gearbox down on the rear of the box between it and the firewall.....
Did you check the globes yet??? (Do this 1st, if they are OK, take it to the dealer....)
post #6 of 8 (permalink) Old 08-25-2006, 06:14 AM
Country: waltrav's Flag is: Canada
waltrav's Avatar
Liz, Here are a few checks I would do, in order, before going to Toyota.
1.Double check the GAUGE Fuze (Drivers side box).
If good, then
2. Remove the Rear passenger side panel shown on the web page.
http://www.at-design.ca/1ravworld/b-quiet/b-quiet.htm
Only do step 3 – 6 (pass. Side will have no 12V connectors)
Then remove the bulb and check it. Also you can check it with a test meter.
If good, then:
3. The Auto transmission has a Neutral Start Switch located on the front/bottom of the tranny.
The Manual transmission has a Back up light switch which looks to be on top of the tranny.
Good luck, Walt
waltrav is offline
post #7 of 8 (permalink) Old 08-26-2006, 10:07 PM
waltrav's Avatar
Sorry Liz I made a mistake for the bulb access
My rear interior was in the house when I checked for an access cover. I missed the cover that resides in the upper storage compartment.
I just noticed it when I installed one panel tonight while insulating.
Cheers, Walt
waltrav is offline
post #8 of 8 (permalink) Old 09-12-2013, 10:52 PM
Country: tufftommy's Flag is: United States
I am trying to find a way to replace a reverse switch on a 2003 rav4 mt 5sp without dropping the tranny. I had the clutch replaced by toyota in burlington nj and apparently the tech stipped the 3 screws that attach the cover to the switch. All of the internet searches show the switch is screwed into the trans housing. If someone has tsb on this please let me know.
tufftommy is offline
