ECM/Transmission problem for 2001-2003 RAV4 - Page 53 - Toyota RAV4 Forums
post #521 of 558 (permalink) Old 03-25-2014, 09:49 PM
Country: jburg1254's Flag is: United States
Module Repair Pro
I started having the familiar transmission issue less than 2 weeks ago and my mechanic immediately suggested that it was an ECM problem, not the transmission. He ran some diagnostics and confirmed the issue. His suggestion was to replace the ECM with a remanufactured piece.
While the car was in the shop, I started searching and came across this thread. I'm a few miles from Module Repair Pro in Van Nuys, so I took my car over there this morning.
For $189 he repaired the ECM and did the removal and installation. Just got back from picking up the vehicle and it drives like a champ again! Thanks to Gino and especially to the posters on this thread for pointing me in the right direction.
jburg1254 is offline
post #522 of 558 (permalink) Old 03-26-2014, 02:01 PM
Country: pogitalonx's Flag is: United States
Same issue as everyone else
Hi everyone,
Our Rav 4 started having transmission issues. On acceleration from stop, it would shift from 1 to 2, then with the accelerator still depressed, would downshift back into 1. When I lifted up on the pedal, it would shift to 3. We took it to the dealer and they said it "might" be the ECM but they wouldnt guarantee it. They wanted to charge us 1k to fix it. Here's a copy/paste from the estimate:
Task:
Observations: HARSH SHIFTING BETWEEN 2ND AND 3RD
AS PER TSB 0156-10 RECOMMEND REPLACEMENT OF ECM/PCM , AND RECHECK, VEHICLE MAY STILL NEED TRANSMISSION IF HARSH SHIFT IS STILL PRESENT.
Other $1,175.45
I immediately went to googling and found this thread. Last week I sent my ECM to the guys at Module Repair Pro and got it back on Monday. Installed it yesterday and drove it around in a stop-and-go pattern for about half an hour as they suggested.
All fixed! Works great! Thank you MRP!
pogitalonx is offline
post #523 of 558 (permalink) Old 04-25-2014, 11:17 AM
Country: c good's Flag is: United States
Congrats on your RAV4. My Mom has the same vehicle with only 63K miles. She had the module reflashed when she bought it from Toyota dealership as a "Certified" vehicle with 35K miles on it in 2007. The vehicle went less than 30 k miles before her module went out. It's such a common problem that it's probably worth just sending it in and having it "fixed" before it's broken and leaves you stranded somewhere.
I was aware of the potential problem years ago but Toyota insisted that the "reflash" would solve the problem and wouldn't do anything for us until it started to act up. They kept shuffling us down the road until it was out of warranty. Two years out of warranty with only 65K miles on it and the transmission started acting up. Toyota wouldn't do squat to help. They wanted $1500 to replace the module and "possibly" another $3500 to fix the transmission if it was damaged due to the bad ECM.
It's very noticeable when it starts to go bad. She was lucky as she just drives locally, no more than a 10-15 mile radius. If it had happened on a long trip it would be a problem. I say fix it now and have some piece of mind. It would also recommend having the transmission serviced (filter and fluid) if you don't know when it was done last. HTH c good
P.S. If possible I would Find out from original owner if ECM/ECU was already repaired/replaced though before sending it in.
c good is offline
post #524 of 558 (permalink) Old 04-25-2014, 01:26 PM
just another heads up on this vehicle. The emissions parameters were too strict on the original ecm programming. This can cause an engine light to come on that will suggest bad catalytic converters. If this happens, have the shop/tech look up the TSB on this problem. It is able to be solved by reflashing the ECU/ECM with the new parameters. DO NOT let them hose you by saying you need new catalytic converters unless they can prove it to you! This might be something to follow up on also to see if it was already done. HTH c good
c good is offline
post #525 of 558 (permalink) Old 04-28-2014, 08:27 AM
Country: Abanks's Flag is: United States
Can I have a copy still having problems with my 05 rav
Abanks is offline
post #526 of 558 (permalink) Old 04-28-2014, 10:35 AM
may i have a copy also
Abanks is offline
post #527 of 558 (permalink) Old 09-12-2014, 02:20 PM
Country: Master slacker's Flag is: United States
Let's bring this back to the top! Had the same slipping, rpm, high gear, CLUNK issues begin this past Sunday. Only drove around the block to return home, yank out the ECM, and send off to Sergei at Check Engine Etc. on Monday. Despite being on "overnight" delivery, it arrived on Wednesday. On Thursday I got it back and reinstalled it with absolutely no issues in operation. No clunk, high rpm, etc... Best spent $220 on this car ever.
Master slacker is offline
post #528 of 558 (permalink) Old 09-13-2014, 08:15 PM
Country: banderso's Flag is: United States
Hi, update.... installed Sergei's ECM at 108000, now at 122000. no issues. Shifts great, idles like it should. I am a happy camper!
see ya
bill
banderso is offline
post #529 of 558 (permalink) Old 09-15-2014, 04:57 AM
Hi, I have been reading this forum for a few months since buying 2001 RAV4 2.0L, awd, auto. Lots of good info. Currently live in Philippines and is very difficult to get advice/info about almost anything regarding vehicle unless you go to dealer. Tnx
Jimbo62 is offline
post #530 of 558 (permalink) Old 09-25-2014, 12:23 PM
Same issues here.....good resolution!
Quick note to everyone on this thread
Thank you very much for the information
2001 RAV4...similar symptoms as everyone else, same dealer dead ends, same transmission replacement quote of $3500.....
Decided I would try a $300 fix before deciding to double my investment in the vehicle
Used Module Repair Pro in Van Nuys, CA - had them ship me a replacement ECM, did the swap in 10 minutes
Vehicle still a little sticky on the shifting, but the overdrive is back, shifting perfectly from 1-2, no skips no missing, have driven about 50 miles so far and it's a completely different car!!
After returning my core, total will be about $240 for the entire fix and didn't even have to have the vehicle sidelined. If you;re not mechanically inclined, I would suggest having a replacement ECM sent and your local mechanic put it in - there was no VIN info needed. This was literally a 10 minute job
Module Repair Pro did a fantastic job (and I'm sure the Bronx guys and the NC guys are just as good) and I really do appreciate everyone's feedback on this issue
Regards
Matt
matt3480 is offline
