500rpm idle in drive - Toyota RAV4 Forums : RAV4World.com
Register Home Forums Active Topics Photo Gallery Garage iTrader Search Today's Posts Mark Forums Read
Old 02-22-2012, 03:44 AM   #1 (permalink)
Country: Torque Splitter's Flag is: United States
Torque Splitter's Avatar
Default 500rpm idle in drive
So this started happening about 2 years ago and the problem hasn't gotten worse or better. In drive the vehicle idles at about 500rpm at a stop. I've tried to adjust the idle screw located at the throttle body with no luck. if i move it up the drive idle will move to about 750rpm in drive but in park will fly up to 1000-1200. It never dies and the IAC is working properly at this time. the only long term problem im aware of it premature mechanical wear due to low oil pressure at 500rpm. Does anyone have the same issue?
someone else also suggested that the torque converter could be prematurely locking up creating an extra load on the motor. I've since dismissed this because it will almost always stall the motor
yeah she may not be the most beautiful thing out there, however I wouldn't trade her for anything. There simply is no light SUV comparison. Go ahead Bluebook it... there's a damn good reason why they hold their value so well
Torque Splitter is offline   Reply With Quote
Old 02-22-2012, 06:20 PM   #2 (permalink)
ARK
Did you clean your IAC and EGR ? Also your intake at the TB could be carbon fouled. A can of carb cleaner sprayed into the throttle body can do wonders or even Seafoam but use it sparingly. If you clean your throttle body do it just before you change oil, then get rid of that oil and put new in.
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
