Brake servo sensor? - Toyota RAV4 Forums : RAV4World.com
Old 12-01-2012, 03:53 PM   #1 (permalink)
Country: biggazzafaetherigs's Flag is: UK
Default Brake servo sensor?
Hi,
I'm looking for a bit of help with my new rav, the brake light on dash comes on are 3-5 pumps of the pedal, fluid level is correct and brakes had been bled correctly,
I thought it might be the sensor in fluid reservoir but un-plugged and still had same problem, plugged it back in then un-plugged the sensor that goes into the brake servo and this stopped the light from coming on, I think this sensor must be some kind of check valve/ pressure sensor of some sort?
Has anybody else had a similar problem, was it the sensor that was causing it or the servo?
and is the sensor available to buy separtely?
Any help/ info much appreciated!
biggazzafaetherigs is offline   Reply With Quote
