2002 won't start - Toyota RAV4 Forums : RAV4World.com
Old 12-08-2012, 01:54 PM   #1 (permalink)
Country: This Old Spouse's Flag is: United States
This Old Spouse's Avatar
Default 2002 won't start
Yesterday my husband was going to move my 2002 RAV, but when he tried to start it, all he got was a very rapid clicking, all idiot lights came on, but it wouldn't turn over. He attached a battery charger and it showed 51% charged.
As far as I know there's no aftermarket accessories that could be draining the battery (which was just replaced at the dealer in May). At least it was in the driveway and we could push it into the garage. But now what? Any ideas?
This Old Spouse is offline   Reply With Quote
Old 12-08-2012, 02:01 PM   #2 (permalink)
Country: cutthroat22's Flag is: Canada
My guess is you need a new battery.
cutthroat22 is offline   Reply With Quote
Old 12-08-2012, 02:18 PM   #3 (permalink)
After 6 months??
Old 12-08-2012, 02:33 PM   #4 (permalink)
Start by getting a battery charger and an extension cord.
Do you have a friend with an electrical meter that can measure the current draw? Or better yet, do you have a friend, with an electrical meter, that can measure the current draw? Current draw would normally be under 50 milliamps (0.050 amps). Your idea of a parasitic load is a good one. If you have excess draw, pull fuses until you find the problem circuit.
Batteries can fail after 6 months. They normally have a warranty.
Old 12-08-2012, 03:07 PM   #5 (permalink)
What about the starter solenoid?
Old 12-08-2012, 03:18 PM   #6 (permalink)
I had thought the car had started after you had the battery charged. That would have pointed to a weak battery problem. The car did not start after charging?
A clicking starter is typical for weak battery or a bad connection. Measuring the battery voltage while cranking would be informative. If the battery voltage is not dropping below 10 volts while cranking, then the problem could be a connection or it could be the starter solenoid.
Old 12-09-2012, 06:44 PM   #7 (permalink)
We pulled the starter and solenoid this morning and cleaned all the contacts which appeared very dirty, and it's been starting ever since. I've had it out a few times today and the problem seems to be solved. Yippee!!
