Country: Join Date: Jan 2013
my rav4 2litre diesel wont start when worm . when been on journey and stoped engine then try startin it back up after a min or two it wont start till it cools down any one any idea
Country: Join Date: Feb 2012
Spray pattern of injectors may be dirty, instead of a fine mist in a V pattern they shoot or dribble droplets or a stream.
Also the delivery system must be tight with no leaks, no air coming into the fuel stream. Verify fuel pressure. Fuel filter must be clean. If it is very cold where you are a 10% gasoline can be added to winterize diesel but no more. If there are glow plugs verify they all work, even 1 failed glow plug can make starting a diesel tough. Remember that compression, a very high compression is used to ignite the fuel/air mixture, if compression is failing due to age, use compression becomes too low to squeeze the air/fuel mixture. The injectors atomize the liquid and feed the right proportions of fuel and air, if anything is wrong the mixture is tougher to ignite. Heat of compression starts the banging. |
