Country: Join Date: Nov 2012
I got a JDM engine to replace my engine, and the fuel injectors and ports on the head are different.
Do you guys know if I should be using the JDM injectors or the US spec ones, or can anyone offer some insight here please. I have been looking online for days regarding this and cannot figure it out. Backstory: I acquired a 99 rav4 A/T AWD from a friend with a bad engine. I bought an engine on ebay and verified it was 3S-FE for AWD (but it is JDM version) So I have the motor out (boy was that a full pull) and I am down to switching the intake manifold from my OEM US engine onto the JDM engine, and I notice that the fuel injectors are completely different. Doing a little more research online it look as if the Injectors are same/similar to what is on a 2001 Rav4 (long skinny type) and mine are for the 99 rav4 (short green type) I would normally just use the green injectors. I can get the injectors from my motor in the head and tighten them up just fine, but the obviously wont poke into the head as far and this could cause spray issues? So my question for you guys is which injectors do I use? and will I need to do anything else? UPDATED PICS OF MY ACTUAL ENGINE AND INJECTORS ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Country: Join Date: Nov 2010
Depends on the ECU you are using. If you're using the JDM computer, use the JDM injectors. US computer then US injectors. Physically, either will probably fit, but the flow rates might be different and the computer will get confused. It will retune itself up to a point (about 10% difference) but beyond that you'll start having problems.
Of course, if you've got an aftermarket ECU, use whatever will fit.
#3 (permalink) | |
I also dont want to throw a CEL. I am just unsure about using the US spec injectors as the ports on the head are different depth. I can put the injectors in and the rail, they just wont fit down in the head as much as the jdm injectors and I worry about the spray of the injectors having an issue. |
#4 (permalink) | |
#5 (permalink) | |
R4W Moderator
Country: Join Date: Dec 2004
Feedback Score: 1 reviews
JDM engines don't have the same emissions standards as US engines... Getting a JDM engine for an OBDII car you may run into many problems with multiple sensors... If you are using a US ECU for a JDM engine you may throw multiple codes since the ECU will search for certain sensors that may be missing or don't even exist on the JDM engine... Head and block may have different sensors... If you are required to go through emissions, you may end up with some issues down the road... Just curious why you did you get a JDM engine ? They really aren't any cheaper then a US engine... Just my .02 cents... |
#6 (permalink) | |
Its a 4wd engine for a 4wd car. This motor was $725 on ebay, and the cheapest locally was nearly double that with over 100k miles on it. It really surprises me that no of you guys have a straight forward answer on this. Hopefully that means these cars dont break very often
#7 (permalink) | |
but you're using the JDMs with your factory ECU and original intake manifold? |
#8 (permalink) |
ok after closer inspection it appears my injectors werent the green ones I originally posted a pic of (my fault for assuming the guy had the same as me).
Anyway now you can clearly see the difference injectors. My gut says just to use the green US verson injectors in the JDM engine as everything else will be US (ECU, INTAKE MAN...etc) |
#9 (permalink) |
Country: Join Date: Oct 2010
You could use them and change them to JDM if they make the CEL come on.
I have seen these being used before, but i really cannot find the thread they where pictured in again. I know however that more people have struggled with this issue. Greetz Pim
#10 (permalink) | |
![]() For the record, the stock JDM injectors are yellow. But yes, the issue is that the ECU needs to know what to expect when it applies pulse to the injector. The green US injectors are 250cc while the yellow JDM injectors are 210cc. So the amount of actual fuel injected on a 2ms pulse will be a lot different between a 210cc and a 250cc injector. But like I said before, the ECU should self tune to a point (10% usually) using the O2 sensor as long as it's working, but you may still have issues. A stock ECU really needs to tie up with the correct injectors for the least hassles. For completeness, here's the injector specs: US ![]() JDM
