Country: Join Date: Feb 2012
Went through a puddle last week, not very deep, 6-10 inches but admittedly a little fast, came out the other side ok but the rav cut out shortly after. Fortunately it was only the electrics that got a bit wet, and it started and runs fine after it dried out.
Now, I've done a search but can't find any information or recommendation on water proofing our little rav4's a little better ? Anybody done this? |
Country: Join Date: Jan 2011
Hmm... I would recommend adding a belly pan as a first defense.
I can talk you through a more detailed walk through if you'd like. I only used zip ties or existing bolts to attach it. I did cut off the lower tabs on the bumper for a different project (air dam), but you could cut out holes in the sheet and keep the tabs. And as far as more permanent, I would suggest looking for any exposed wires. I'm no expert, but for it to cut out like that, I would think there's something exposed.
~Cherish & RAVadoodle~ _____________________________________ RAV4 Picture Game - Come play! ![]() Monthly Fuel-efficient meet-up in Spokane WA/Coeur d'Alene ID (1st Sat, any vehicle) EcoModder - Top 10 vehicle Lists for MPG |
Country: Join Date: Jan 2013
Hi there, just noticed your post and thought I would offer up my 2 cents. I have lots of experience with this stuff and I do electrical for a living.
Myrefuge made an excellent suggestion, I had the same problem on my toyota van, and putting a belly pan helped out alot I'm not sure if they make them anymore, but a cover for the distributor to protect against light splashes would also help out. The most likely culprit in alot of cars are splashes and moisture in/on the distributor Lastly, this sounds abit anal, but whenever you have an electrical connector that may be exposed to water or weather, I like to treat it with Penetrox or similar product. It is a grease that protects against corrosion for electrical parts. You don't need to open all your connectors and apply it, but if you happen to be doing a repair and come across a connector that needs it, squirt some in, you'll thank yourself the next time you need to undo a connector and it isn't corroded to dust. Hope this helps Cheers |
