my 2003 rav4 has a 2.0 engine and it's knocking & i know it needs to change; I came upon a vendor who offered me a 2.4 engine saying it's compatible ( or i's the same engine) he said all I have to do is transfer all of the stuff that is attached from my old engine to the replacement & I can use the same wire harness and ECU. For anyone who knows is this just a straight swap or does it need some mods . The engine is imported as low mileage from japan.........
NNNooooooo, this is a major job. the 2.4 s ECU will have to be used, harness, electric throttle pedal, gear shift mech, is he just selling you a motor or are you getting a front cut? Will the gearbox bolt up?
There are major differences in ignition systems and ECUs
Had you thought about an upgrade to a 3t-gse Caldina or gt4 Celica motor. This would be easier and give you more HP in the end.
Beams motor?
Might just be better to go with a straight replacement, or rebuild the old one.
Beams motor?
Beams motor?
So if the 1azfe to 2azfe is bigger ...I am curious don't you need a different transmission to install the 3sgte, ECU, etc. I just don't see how this would be easier...I hope that it is....just trying to understand the process. I have a 2002 rav4 (2nd gen) and every 3sgte swap I see is a manual first gen....is the GT4 celica an automatic? will it work with a 4wd? thanks for the info.
The project is finished.
I am really happy I did it, the car runs smoother and the engine picks up way faster and has more power.
Because I changed from the D4 engine I changed the following, the engine, the complete loom, the computer, the maf sensor, the oxygen sensor, and the temperature clock.
Not sure if you change from a 2 liter vvti to ta 2.4 vvti if you need to changed these items too.
This the resonse I got from the engine vendor. Im located in california I know these 2003 rav 4's come with 2.0 engine & in 2004 they started having them with the 2.4 wich is also in Scions' camry's and highlander; iv'e been comparing parts from the 2.0 and 2.4 and there the same the externals and timing chain cover etc. So if anyone has done this please let me know.
In simple language I would like to tell you that long block (means head & bloc) of both 2.4 LTR 2AZ FE & 2.0 LTR 1AZ FE is exactly same. All you have to do is transfer all external parts / accessories from your 1AZ FE 2.0 ltr engine i.e Intake, exhaust manifold, alternator, p/s pump., AC compresor, pulleys, timing cover, oil pan etc.
That is all you need to know. If you don't trust us there is nothing I can do. 2.4 ltr engine comes out of many different vehicles like Toyota Highlander etc but long block is same. ALSO ALL EXTERNAL PARTS THAT YOU WILL TRANSFER WILL FIT PERFECTLY as bolt holes are same.
From experience I can tell you it needs more than just an engine as you can read in my post that was linked to above.
I actually sold the car at the end of last year because it was continiously given problems which was more related to a bad job by the electrician than to the engine itself.
I switched from a d4 to a 2.4 vvti so I am not sure what the difference would be from switching from a 2.0 vvti to a 2.4 vvti
External engine parts will bolt on straight but I am sure that the ecu and some of the wiring loom is different and airflow sensors are different too.
what im understanding you went from a diseal engine to a gasoline of course the computer & wiring would be different the vendor has sold these engines for the rav 4 without any problems & I was assure the onboard Ecu or computer is very compatible wire harness from my old engine......... Any one any more thoughts .
We in the u.s dont have diseal engines for these types of cars..
The 1AZ-FSE is a 2.0 L (1998 cc) version. Bore is 86.0 mm and stroke is 86.0 mm. Output is 155 hp (114 kW) at 6000 rpm with 145 ft·lbf (192 N·m) of torque at 4000 rpm. The 1AZ-FSE features Toyota's D-4 direct injection system.
Applications:
Toyota Avensis
Toyota Avensis Verso
Toyota Noah/Voxy
Toyota RAV4
Toyota Gaia
Toyota Isis
Toyota Caldina
Toyota Wish
Toyota Allion
Toyota Premio
Toyota Opa
I have this currently;
1AZ-FE
The 1AZ-FE is a 2.0 L (1998 cc) version. Output is 108 kW (145 hp) at 6000 rpm with 190 N·m (140 lb·ft) of torque at 4000 rpm.
Applications:
2006–present Toyota Camry (Aurion version)
2001-2003 Toyota Rav4
was planning to get this:
2AZ-FE
The 2AZ-FE is a 2.4 L (2362 cc) version built in Japan and at TMMK in the USA, obtains a total displacement of 2362 cm³ with 88.5 mm (3.5in) bore and 96.0 mm (3.8-in) stroke, resulting in a compression ratio of 9.6:1. Output is 157 hp (117 kW) at 5600 rpm with 162 ft·lbf (220 N·m) of torque at 4000 rpm. The 2AZ-FE also has one-piece cast camshafts. Output for the 2007 Toyota Camry is 158 hp (118 kW) and 161 lft·lbf of torque. There is also a version of the 2AZ-FE engine with 161 hp (120 kW) and 163 ft·lbf (221 N·m) of torque made in Japan for the Scion tC. A 166 hp (124 kW) version is in the 2006 and newer Rav4. This engine is available for the Toyota Matrix and Pontiac Vibe twins as well as the Toyota Corolla beginning in the 2009 model year.
A TRD supercharger is available on the Scion tC.
Applications:
2002-2009 Toyota Camry
2009- Toyota Matrix XRS
2009-2010 Pontiac Vibe
2009- Toyota Corolla XRS (2009-)
2003-2009 Toyota Camry Solara
2006-2008 Toyota RAV4
2001-2008 Toyota Highlander/Kluger
Toyota Estima / Toyota Previa / Toyota Tarago
Toyota Alphard
Toyota Blade
2005- Scion tC
2008- Scion xB
The 2007 Toyota RAV4 produces 166 hp (123 kW) at 6000 rpm and 165 ft·lbf (224 N·m) of torque at 4000 rpm [1].
You are asking for advise when you seem to know the answer already and don't want to listen what other people advise you.
Even though people telling you that it is not a straight swap you tell them it is.
Why bother to make a post like this if you are sure you know the answer already, maybe it is your post count you are doing it for.
I am pretty sure that an ecu for a 2liter engine is different than for a 2.4liter engine, maybe you should call you local dealer and ask them to compare some part numbers of some items (like ecu, airflow sensor, oxygen sensor etc etc), guarantee you that they are different, especially that the engine is for JDM and I am guessing that your car is from the USDM.
The externals like altenator, starter etc ect will bolt straight on though
If you believe it is a straight swap I would say go ahead and do it, you will notice the difference in power of the engine right away, the 2.4 liter engine is a decent size engine for the rav4 as I alway believe that the 2 liter is underpowered for the weight of the rav4.
Mine was driving great with the new engine and had a lot more power but was giving problems due to a electricain who did a very messy job wiring up the engine.
NO offense on the post; im trying to gather info that's all and I was not familiar with the D4 Engine I was just doing research on that D4 & comparing: but I do appreciate the info. Any pictures on your old rav 4 engine etc.'
IMHO - i think there is no much problem to swap 1az-fe to 2az-fe, but need rav4 2.4 ecu, maybe another parts such as bush or other. But in main - i can t see any big problem. Or search for rear - crashed rav4 witn 2.4 engine and make-a-swap
I change 1 chevy engine before but that was a straight v6 Not a front wheel drive engine
im sure i can do it ; im very mechanically incline just have to take my time. The pople from engine world usa told me that the ECU & engine harness and all external components are 100% compatible; I asked the guy if they sold 2.4 engines for 2003 rav 4 s he said yes a lot and so far no complaints.. Have you done this swap........
Finally how is your RAV4 2003 performing with the 2.4 Liters engine..I am about to install a 2004 scion TC engine (2.4Liter) in liitle RAV4 2001 that the engine was destroyed when in a car accident( hit the lower part of the engine against to a big rock...oil pan and timing cover are broken and also other stuff inside the engine)
I really appreciate if you or anyone else can give a feedback agout swapping engine for 2.4Liters..thanks
we put a 2AZ-FE 2.4 into a 2002 rav4 last year. The motor was brand new in a box and all we did was change the front plate because the engine mount was different. This motor was made for Camry. Motor cost was $3650, clutch $180. took my son and i a full day to do the swap.
fuel economy is not that good but we don't have anything to compare as when we bought the car the engine was blown.
Uses 12-13l/100km around town and down to 9l/100km on the open road. Resent trip with roof rack and loaded was 13l/100km. Would like to change ECU but the cost would possibly be more than the savings.
Hey guys I am new to this site and I need help I have a 2005 rav 4 that has the 2.4 and recently it blew up I then purchased a 2001 rav 4 engine witch is a 2.0 I don't care if the engine is gonna give me less power my concern is more about running right and is the swap gonna need modifications please get back to me asap I am trying to change engine this weekend thanks
Hi guys I’m new to this site and I was having the same problem with a 02 Rav4 that has a 2.0 engine and after I read all your comments I decided to do the 2.4 so I can share my results and here I’m and just to let you all know YES you can do the upgrade to a 2.4 or the downgrade of 2.0 and trust me y’all be happy with the results
I also did the 1AZ to 2AZ swap.... very easy swap. I kept all the external parts, sensors, wiring and ECU from the 1AZ. If I remember correctly; the ECT (engine coolant temperature sensor) was different... and the knock sensor. If the engine come off a different vehicle than a RAV4; you'll need to swap the valve-cover to bolt the air filtrer box, and the timing chain cover because the motor mount that bolts to it is at a different angle.
