| 4.2 D.I.Y. and Modifications Share your RAV4.2 projects and ideas for future mods here! |
Country: Join Date: Sep 2012
First, let me say thanks to all for sharing your videos and detailed info on all the DIY projects. You guys make up for having a father that thought girls don't play with cars...I have saved a lot of money and gained great sense of accomplishments from following your guidance and getting the job done myself.
Now, a question: Does anyone have the torque specs for the rear shock assembly fastners on an 04 or any second generation? I know I can get them by purchasing a repair manual, but I thought I'd check the forum first. Cheers |
Hi Houston !! the specs have landed lol
Application Ft. Lbs. (N.m) Axle Hub-To-Rear No. 1 Suspension Arm Bolts 37 (50) Camber Adjust Cam Bolt 83 (113) Drive Axle Lock Nut 159 (216) Drive Axle-To-Differential Side Gear 41 (56) Rear No. 1 Suspension Arm Toe Adjust Cam Bolt 97 (132) Shock Absorber Shaft Nut 11 (15) Shock Absorber Lower Mounting Bolt 27 (37) Upper & Lower Suspension Arm Nuts 76 (103) INCH Lbs. (N.m) ABS Speed Sensor Bolt 71 (8.0) Hope these work for you I copied them out of suspension torque specs 2005 rav4 watch out for skin off the knuckles and the nails (gloves are the go) goodluck |
