| 4.2 D.I.Y. and Modifications Share your RAV4.2 projects and ideas for future mods here! |
#11 (permalink) |
Country: Join Date: Dec 2012
It sounds like you installed new pads without turning or replacing the rotors.. which is always going to make for a noisy situation in my experience... then you got the rotors turned... You will still get a squeek at least for a while until you re-wear the pads to the new surface of the rotor. That might be a long time.. might wear the rotor a little weird too.. not sure. Usually you do both (new pads, turn rotors) at the same time... then no squeek... but shims are important and could be even more important in this case.
#12 (permalink) | |
![]() It's recommended that rotors be replaced NOT turned. When you turn you lose metal and have less metal to deal with the high heat of ceramic pads. I never had any brake noise. I do lube my shims and sliding pins at least once yearly in the past but from now on twice yearly because of high heat from ceramic pads. ![]() I would say the OP needs grease on shims/sliding caliper pins. Also what material are the new pads, organic, semi-metallic or ceramic? My 2004 calls for ceramic. New shims usually come with the new brake pads. Last edited by ronbo1313; 12-05-2012 at 02:16 PM. |
