2007 RAV4 no electrical on back door - Toyota RAV4 Forums
post #1 of 13 (permalink) Old 05-08-2015, 03:51 PM Thread Starter
Hi all,
Puzzling issue... I have no power to any components on my back door. The 3rd light doesn't work, nor does the light inside the car (on the door), neither does the back wiper. Any thoughts to quickly eradicate this problem?
Thanks!
jamestss21 is offline
post #2 of 13 (permalink) Old 05-08-2015, 04:34 PM
First thing to check is the fuse. I am not sure where the fuse is as there are some close to the hood level and another 2 locations under the hood.
FYI, there are extra fuses as well as fuse puller under the hood in one of the fuse boxes.
Good luck.
vanib is offline
post #3 of 13 (permalink) Old 05-08-2015, 04:39 PM
The diagram in the link shows the fuse locations next to the hood level, close to the steering column. Maybe it is the one that says DOOR alhough I am guessing it might be the driver's door. check TAIL, RR Door, RL Door too.
Wiring diagram. Need to install heated seats
Maybe the Rear door fuse in the other 2 fuse boxes under the hood.
vanib is offline
post #4 of 13 (permalink) Old 05-08-2015, 04:48 PM Thread Starter
Thanks Vanib.
Does anyone know which fuse I need to check? I'm pretty novice at this... Sorry!
post #5 of 13 (permalink) Old 05-08-2015, 04:52 PM
Start with TAIL. Look at the picture; that picture is also on the inside of the fuse box cover.
Because these fuses are mini low profile (i.e. pain in the a$$ to reach with your hands or even with regular pliars), find the fuse puller in one of the 2 fuses boxes under the hood.
I believe the owner's manual will point your in the right direction to locate the 2 fuses boxes under the hood. They are actually in plain view on the left and right. Gently pull the covers off. Even there the covers has matching diagrams telling you where the fuse fuller is (imagine a small tweeer) as well as spare fuses.
Always replace with fuse with the same capacity.
Also, just noticed that also mentioned that the rear wiper does not work. I believe the rear wiper is RR WIP fuse, again near the hood lever inside the car.
vanib is offline
post #6 of 13 (permalink) Old 05-08-2015, 05:04 PM Thread Starter
Ok, checked those fuses and they do not look blown. Other thoughts? Basically it seems like there's no power at all to that back door.
post #7 of 13 (permalink) Old 05-08-2015, 05:57 PM
Check the cable from the body to the door. It carries all those power wires, is inside a rubber cover and may have been compromised somehow.
Dr. Dyno is offline
post #8 of 13 (permalink) Old 05-08-2015, 10:17 PM
Rickl's Avatar
Dr. Dyno is correct. This is the only component that is common to both the wiper and the light on the rear door.
However it is very unlikely that a single wire in this cable would break, let alone several.
Is it possible that the switch on the light has been turned off, or the bulb is burnt out? It's more likely that you only have a problem with the wiper.
If you can eliminate those two possibilities with the light we can concentrate on the real problem.
Rick L Ontario Canada
Rickl is offline
post #9 of 13 (permalink) Old 05-08-2015, 11:04 PM
So you have no brake light on the spoiler, no inside light on the door (make sure swith is not off)? How about the light for the rear licence plate(the headlights have to be put on first) ?
vanib is offline
post #10 of 13 (permalink) Old 05-08-2015, 11:50 PM
There must be a ground cable going from the door to the body. Surely they're not using the hinges and latch as a ground?
JuneBug is offline
