Replacement Keys - Toyota RAV4 Forums
post #1 of 43 (permalink) Old 05-12-2007, 12:58 PM
DesioMedia
Replacement Keys
Hi,
I lost one of my keys for my Rav4 and am trying to get a replacement. I went to the dealer and he wanted to charge me $500! How can I get a new key and reprogram it for less than $200. Also if I found a blank key how would I program the transponder?
Thx
post #2 of 43 (permalink) Old 05-12-2007, 01:57 PM
luigi524td's Avatar
Re: Replacement Keys
Originally Posted by DesioMedia
Hi,
Thx
This is the programming sequence for Lexus -- likely to be simliar for the Rav4 but I'm certain if it isn't, someone will have it for you ASAP. The replacement key should NOT cost you $500! But it will not be cheap ...
DRIVERS DOOR OPEN AND KEY REMOVED FROM IGNITION SWITCH .
INSERT KEY INTO IGNITION SWITCH , THEN REMOVE IT .
WITHIN 40 SECONDS -
PRESS LOCK AND UNLOCK ON THE VEHICLE DOOR LOCK SWITCH AT 1 SECOND INTERVALS 5 TIMES .
CLOSE AND REOPEN DRIVERS DOOR .
WITHIN 40 SECONDS -
INSERT KEY INTO IGNITION SWITCH .
SWITCH INGNITION "ON" AND "OFF" ONCE TO PROGRAM A NEW KEY CODE WHILST RETAINING THE ORIGINAL CODES OR TWICE TO PROGRAM A NEW KEY CODE WHILST ERASING THE ORIGINAL CODES .
REMOVE KEY FROM IGNITION .
*SYSTEM SHOULD NOW LOCK AND UNLOCK VEHICLE , ONCE OR TWICE DEPENDING WHICH MODE HAS BEEN SELECTED*
WITHIN 40 SECONDS -
SIMULTANEOUSLY PRESS AND HOLD KEY "LOCK" AND "UNLOCK" BUTTONS FOR A MAXIMUM OF 1.5 SECONDS .
WITHIN 3 SECONDS : PRESS ANY KEY BUTTON FOR A MINIMUM OF 1 SECOND .
NOTE --- IF SYSTEM LOCKS AND UNLOCKS TWICE VEHICLE TWICE , PROGRAMMING PROCEDURE HAS NOT BEEN COMPLETED .
NOTE --- A MAXIMUM OF 4 KEYS CAN BE PROGRAMMED .
NOTE --- TO EXIT THE PROGRAMMING MODE : CLOSE DRIVERS DOOR OR INSERT IGNITION KEY .
luigi524td is offline
post #3 of 43 (permalink) Old 05-13-2007, 12:11 AM
Country: Carnivore's Flag is: United States
Carnivore's Avatar
I knew these keys would be a ripoff if they got lost or damaged.
It would be cheaper to get a standard ignition key cut and put in an aftermarket keyless alarm system with a separate fob. Unless you've got the immobilizer of course, in which case they've gotcha.
Carnivore is offline
post #4 of 43 (permalink) Old 05-13-2007, 06:56 AM
Country: dtown40's Flag is: United States
Send a message via Yahoo to dtown40
You might try ebay?
dtown40 is offline
post #5 of 43 (permalink) Old 05-13-2007, 09:44 AM
desertguy
I have not lost or damaged an ignition key or remote in 30 years so I'm not going to get too concerned.
post #6 of 43 (permalink) Old 05-14-2007, 10:26 AM
The G Man's Avatar
Hi,
Thx
You have the limited, thats why it cost so much to replace it. Find a blank on ebay, get it cut from a specialize lock smith. Sometimes the blanks will come with instruction for programing, if not, then the above instruction should work as well.
Good Luck
The G Man is offline
post #7 of 43 (permalink) Old 05-20-2007, 06:40 PM
Hi,
Thx
If you can live without the remotes, a dealer will sell you just a regular key very cheaply.
chows4us is offline
post #8 of 43 (permalink) Old 05-21-2007, 03:30 PM
The G Man's Avatar
He has a limited, so the key wont be cheap, it has a immobilizer chip in it.
post #9 of 43 (permalink) Old 05-22-2007, 12:28 PM
Hi,
Thx
I asked my salesman yesterday and he thought a replacement key/fob would run under a hundred bucks. You might want to call another dealer or Toyota directly.
Briant73 is offline
post #10 of 43 (permalink) Old 05-22-2007, 12:45 PM
jmhunter's Avatar
what is the imobilizer
jmhunter is offline
