FIAMM Horn Upgrade - Page 2 - Toyota RAV4 Forums : RAV4World.com
Old 10-24-2011, 12:25 PM   #11 (permalink)
I have thought about changing the horn the first day I got my RAV. I think the stock horn sounds like a weenie. I may consider a new horn - it doesn't look too painful to replace. Good post.
I guess I could use some other models horn. This week, during my commute, I may work on getting honked at so I can hear different vehicles horns and maybe do some comparisons. lol.
Current Vehicles:
2011 Toyota RAV4 Limited
2008 Honda Civic
Boar is offline   Reply With Quote
Old 10-25-2011, 08:16 PM   #12 (permalink)
Sr5Vr6Rav4's Avatar
Default Fiamm horn
I'm well over do for a horn upgrade. I went over to Amazon to look up the Fiamm horn line-up. Looks like these two models will work well together:
Fiamm 72112 and Fiamm 72102.
I'm curious if I'll need a relay to give it enough juice. (HELLA 003510087 30 Amp). Any thoughts?
Sr5Vr6Rav4 is offline   Reply With Quote
Old 10-25-2011, 10:23 PM   #13 (permalink)
Country: Deanjet's Flag is: United States
Deanjet's Avatar
Those are the same FIAMM Freeway blaster horns I used. The stock wiring and relay seam to work fine. But, I am not one to just leave my fist layed into the horn when I get angry at another driver. Too much road rage and crazy people where I live, not worth risking my life. I want to be heard, not shot!
2011 RAV4 SPORT V6 AWD
The greatest pleasure in life is doing what people say you cannot do.
Deanjet is offline   Reply With Quote
Old 10-25-2011, 10:25 PM   #14 (permalink)
Deanjet's Avatar
Originally Posted by Fastontheturns View Post
did you use dual freeway blasters ? or the high and low tone fiamm horns ?
FIAMM Freeway Blaster's, high and low tone (Fiamm 72112 and Fiamm 72102)
Old 11-21-2012, 09:20 AM   #15 (permalink)
Since the Toyota horn is not so loud and there is a pair, I might want to change just one horn. Keep one loud and one ... anemic!
Which one should I order or should I really change both?
When you honk, are both horns used at the same time or is one used for honking and another for giving beeps e.g. when you lock the doors. If possible, I want to keep the door locking sounds low (don't want to wake up the kids when I come home late)
vanib is online now   Reply With Quote
Old 11-21-2012, 11:03 AM   #16 (permalink)
pico's Avatar
Train Horns & Train Horn Kits: Loudest Horns Available
And an install on a RAV4: http://www.hornblasters.com/installs/set/?wesleysrav4
A guy in town has train horns. Since we do have trains running through town, it's damned scarey when he uses them.
pico is online now   Reply With Quote
Old 11-21-2012, 12:16 PM   #17 (permalink)
That would sound very bad. You want to change both horns, one has a low tone and the other a high tone. I recommend the FIAMM El Grande horns, they are loud, made in the USA and around 20 bucks.
Yes, when you honk, both horns sound simultaneously. The door lock beeper is a totally separate unit.
Old 11-21-2012, 02:17 PM   #18 (permalink)
Thanks JuneBug. It is a better deal than buying the Freeway Blasters separately. I suppose it is still plug and play and fits in the default location.
Should I remove the red housings or are they facing the radiator? I don't want to make them visible from outside.
Old 11-21-2012, 07:07 PM   #19 (permalink)
They were plug and play for me. Just be careful not to let them rub against the A/C condenser. The red plastic housings can be easily removed.
Old 02-06-2013, 10:20 PM   #20 (permalink)
Originally Posted by Deanjet View Post
...Also, the horns are a lot larger than stock, so I had to twist the inboard horn bracket to keep the horn from riding against the grill. Just take off the upper radiator support brackets and you will have plenty of room to get the job done....
I followed your advice and things went smoothly. However, I am not sure if it's just me but these horns don't seem much louder than the one on the RAV The FIAMM El Grande definitely have a different tone. My remote starter uses the horns when locking/unlocking. So that sound has changed too. I also did NOT use the relay hhat came with the package.
I will test it tomorrow as I drive to work.
BTW, my old horns had the following markings:
. MR-FH-03 MARUKO SM-70 E13 000030
. MR-FL-03 MARUKO SM-70 E13 000030
