can't figure out how to deal with Techstream - Toyota RAV4 Forums : RAV4World.com
Old 11-28-2012, 03:07 PM   #1 (permalink)
Country: donreeder's Flag is: United States
Default can't figure out how to deal with Techstream
Hi all,
I'm fairly new here and I'm a computer dummy. I've been reading about the wonderful things you can do with Techstream so I bought it on e-bay. I received it today but I can't figure out how to get it going. Its version V7.10.030 and it came with the cable and two mini-discs. One says Techstream on it and has an Application File calledJ2534 - Mangoose Pro, a PDF J2534 Mangoose Pro Quick Start file, a TISKEY allpication file, the Techstream 7.10.030 application file, and a folder labeled DRIVER.
The other mini disc has "Toyota Techstream7.20.041, TIS KEY, MCVI Driver for Toyota, and MINI-VCI TIS" ALL .RAR files, and an application file J2534 - Mangoose Pro.
I have extracted the .rar files and now have .exe files for them.
The instructions from the PDF file are at best vague. I will give you exactly what it says:
1. Installing original OEM diagnostic software
Must first install the original OEM diagnostic software
Configuration options based on your product installation:
TIS Techstraem
2. Installation J2534 - Mangoose Pro.exe;
Double click the installer. Setup Wizard screen appees Click [OK]
to complete the task
3. Installation in North America activator TISKEY.exe;
OEM factory diagnostic software must be carried out after installation
is compklete
4. Install J2534 - Mangoose PRO USB drive
Connected for the first 2534 - Mangoose PRO USB cable to the PC, when
prompted to find a new hardware, press the USB device is installed properly
5.Click to go to TIS detection software, this time to completer the task
I have run Toyota Techstream 7.20.041.exe and then J2534 - Mangoose Pro.exe, but when I run the J2534 software I get a screen that shows "J2534 Technology" with a picture of a laptop on left, the Mini-VCI cable in the center, and a car on the right. Then there's a picture of the Mini-VCI cable on the bottom left with a green checkmark and a dialog box in the center with two question marks in it. If I try to make an entry in the box the screen goes away. I never get the setup screen as described in step 2.
I'm at a complete loss as to what to do. As I said I'm a computer dummy.
Please somebody HELP!
donreeder is offline   Reply With Quote
Old 11-28-2012, 04:07 PM   #2 (permalink)
Default OK, I got it working - almost
OK, I finally got it to work! Well almost. I can now load everything and can connect to the car, but I can't figure out how to change anything. Perhaps something simple like the seat belt alarm. Any help would be appreciated.
Old 11-28-2012, 04:48 PM   #3 (permalink)
pico's Avatar
Have you opened the PDF file? It has beginning instructions.
pico is online now   Reply With Quote
Old 11-28-2012, 08:45 PM   #4 (permalink)
The PDF file is simply the instructions I listed in my original post. Its of no help figuring out how to change anything.
Old 11-28-2012, 09:22 PM   #5 (permalink)
Country: Rebelcuz's Flag is: United States
Is all that horrible misspelling and pig-English EXACTLY as it appears in the PDF??? How is anyone supposed to follow such sloppy instructions?
Rebelcuz is offline   Reply With Quote
Old 11-29-2012, 12:43 AM   #6 (permalink)
OK, click on Connect to Vehicle. After it connects, click on customize. You will see a screen that says "Select Customize Function"--click on Warning. From this screen you can disable the seat belt warning for the driver's side, passenger side, or both.
Old 11-29-2012, 10:29 AM   #7 (permalink)
OK, I got it. Thanks Junebug ! I guess I wasn't looking closely enough. I feel really stupid now and it seems really obvious now. Thanks again.
Old 11-30-2012, 11:30 AM   #8 (permalink)
Don't feel stupid, we've all been there! Everything's obvious after you figure it out!
