RAV4 V6 Water Pump - Page 3 - Toyota RAV4 Forums : RAV4World.com
Old 12-31-2012, 02:35 PM   #21 (permalink)
Blogson's Avatar
Originally Posted by keeton View Post
Examples of the second? Recalls shouldn't be confused with service campaigns or TSBs.
Suggest that you do an internet search. Also, there is this: Motor Vehicle Defects and Safety Recalls: What Every Vehicle Owner Should Know | Safercar.gov | NHTSA
Jim
2011 Upgraded Base V6 4WD
2002 Craftsman LT1000 V2
Jesus is Lord
Old 12-31-2012, 02:50 PM   #22 (permalink)
Originally Posted by Blogson View Post
About the RAV4 V6 water pump problem, it would be appropriate for Toyota to do what Honda has done, in relation to another situation.
Do you have reason to believe that RAV4 water pumps fail at a higher than average rate?
I am pleased that the water pump is covered under the power train warranty. It is not so on many cars.
Old 01-01-2013, 11:41 AM   #23 (permalink)
friendly_jacek's Avatar
It's pretty self evident on this blog. Some people went through 3 pumps. I have no doubts that pumps are defective and/or pink coolant makes them fail more.
Old 01-01-2013, 11:44 AM   #24 (permalink)
Didn't you have the oil line recall in RAV4? It's all about money, if enough catastrophic failures happen under warranty, it could be cheaper to do a recall instead.
Old 01-02-2013, 08:12 AM   #25 (permalink)
So if my water pump has not been replaced by now (2008 V6 with 88K miles) should I be ok? I am only asking because I only have 12K miles left on my platimum extended warrenty
Thanks
Torwadeo is offline   Reply With Quote
Old 01-02-2013, 12:22 PM   #26 (permalink)
Thanks
Man i wish i took pictures for my leaking WP (i4 awd sport 50k miles). I had no signs of leaking on the garage floor, but there were tiny crystals on the black felt panel inside the hood directly above the belts, pulleys. Also, when the pump was removed inside the pulleys was filled with crystals (white but mainly pink colored) and the serpentine belt had white residue all over but of course on the ribbed side so only visible when removed or gently lifted off the alternator pulley. My message you may not find coolant on the floor, but a big sign is white crystals on the black felt panel... If i were you i would take it to dealer and have them inspect it for a leak, primarily the weep hole test (search for tsb on water pump leak diagnosis to become familiar with the design and the test for a leak). If you havent already, take it in for a recall and ask for WP to be inspected,; usually during the recalls the dealer will do a complimentary inspection and wash as a courtesy (ask about the type of wash, you dont want to introduce swirls from a brush or hand towel drying).
