#11 (permalink) |
Country: Join Date: Jan 2009
Meritorious I would say.
I think we can agree that measuring the temperature in the box would be best to avoid icing. However outside air at 40F can pretty much only be 100% or a little more relative humidity. When the heater raises that to 60F or more, that air is pretty dry. Our RAV4s will not allow recirculate in the defroster positions. Not running the compressor in Defrost settings when the coil temperature OR the outside temperature is low enough would make sense too.
2009 V6 4wd Base |
#12 (permalink) |
Country: Join Date: Feb 2011
If the outside temperatures are below freezing, that air will be extremely dry as virtually all of the moisture will have already condensed out - no need for the air conditioner to dehumidify that air, it's being done my mother nature already.
The volume inside the Rav is pretty small if you have wet stuff and one or more folks breathing in there. Warming the interior without exhausting all the extra moisture via turning off the recirculating function will quickly make a mini sauna inside! Even when it's raining and warm outside, I find the defog always works better with recirculate turned off, with or without the air turned on.
WJBertrand 2011 Rav4 |
#13 (permalink) |
Country: Join Date: Jul 2006
I believe that the compressor is always running as it is a variable displacement type.
4ever 2013 LIMITED Old Age isn't so bad when you consider the alternative. (Chinese proverb) |
#14 (permalink) |
Country: Join Date: Nov 2012
As you know I have paid very close attention to the behavior of my Rav while running a/c. In the morning when it's below freezing my RPMs do not jump from 700 to 900 when I turn on defrost. This has been tested when the engine was warm and driving 20 miles to work.
2012: I4: Base: 4WD: Silver Retired: 2004: H6: Outback sedan: Green 1994: Maxima: Grey 1991: Maxima: Grey 1987: Maxima: Silver Why do I use 85 octane with my Rav? Because I can. |
#15 (permalink) | |
Country: Join Date: Oct 2006
This is according to the shop manual. |
#16 (permalink) | |
Country: Join Date: Aug 2007
Large differences between inside and exterior temperatures (compared to the set point) results in larger displacement of the "variable displacement" compressor, or more heat from the heater. When the solar sensor detects more sunshine it also increase cooling because it anticipates an increase in interior temperature even though the interior sensor has not yet detected a temperature rise. The sensor on the evaporator coil is present on any vehicle with AC.
#17 (permalink) | |
The discussion topic was what ambient external temperature inhibits the compressor from engaging when you want it to dehumidify the cabin in cold weather. Last edited by keeton; 01-04-2013 at 07:19 AM. |
#18 (permalink) | |
I looked over the manual and found that the ambient temperature sensor is connected to the dashboard display, and also to the A/C amplifier. I was surprised to find that both the automatic and manual systems have A/C amplifiers. I cannot find any reference in the manual that the exterior sensor will shut off the compressor. If I look under the chart for compressor not operating, it lists a number of reasons including the evaporator sensor, but no mention of the exterior sensor. The only thing I can find of interest is that the diagnostic tool will show an open circuit of the exterior sensor when the temperature drops below -23.3C or -9.94F. If you could refer me to the page that you found your information, I would appreciate it. It seems to me that if the air blowing through the evaporator was above freezing, then there is still an opportunity to remove additional moisture.
#19 (permalink) | |
After pouring through a zillion tedious .pdf files (most of which are merely remove/replace operations of the various A/C components), the closest thing I found was in a "body electrical" file that had a description of the A/C system and compressor operation, it stated that the solenoid that governs the variable displacement feature is governed by "various sensors". However it does explicitly say in the owner's manual (Chapter 3-1, page 224 for my 2010 US model) that: "When outside air temperature approaches 32°F (0°C) The air conditioning system may not operate even when A/C is pressed." Which of the "various sensors" that trigger that will remain a mystery. |
#20 (permalink) | |||
It's only fair after all the digging I did after your last post.
Cars used the evaporator sensor decades before computer control became common. It is the most reliable sensor to avoid icing, and it still allows the compressor to run when exterior temperatures are below freezing. Why would they trust this important task to something that could malfunction?
