Country: Join Date: Jan 2013
Anyone have trouble with the front defrost/defroster/defogger not working well in the 2012 Rav4 Limited? I can run mine on high for some time and it will not defog/defrost the front and/or side windows completely. Leaves a large amount of fog in the corners and top of front window and side windows stay fogged up. Results in VERY bad visibility out the front and side windows.
Country: Join Date: Oct 2009
New cars will outgas from the plastics and other materials, and these will coat the windows and lead to easy and increased fogging. Our new cars required practically monthly cleaning of the windows for the first couple of years, until that new-car smell was gone.
That being said, our Rav clears the window just fine. As long as you don't have a lot of sopping wet things in the car, the defrost mode seems to clear everything within a few tens of seconds at most. Also, with a limited, I think you can actually run the defroster without turning on the A/C compressor, so make sure your A/C light is lit.
Country: Join Date: Feb 2011
As metioned above, make sure your air conditioner is on when in defog mode, but also make sure that you have selected fresh instead of recirculated air. In my experience, most cars, including our Rav4, defog much more efficiently using fresh air.
WJBertrand 2011 Rav4 |
#4 (permalink) | |
Country: Join Date: Nov 2008
#5 (permalink) | |
Country: Join Date: Oct 2006
However - the AC compressor will not be running if the ambient temps are near freezing or below. Since most of the Midwest is covered with a snow pack right now, I bet that is the case. I would double-check the recirculate button, however. |
#6 (permalink) | |
Country: Join Date: Aug 2010
I would speculate the inside ambient temperature reading is used because the outside temperature is always below freezing up here. If the outside ambient temperature from the front bumper sensor was used for compressor cut-out, there would be no defrosting all winter. Maybe someone is handy with the wiring diagram to confirm the decision logic for the Defrost circuitry?
2010 RAV4 V6 Sport 4WD SAP |
Country: Join Date: Jan 2010
When I see other cars fogged up and mine and most others aren't I wish I had some way to pull them over and hit their Recirc Off button.
#8 (permalink) | |
Country: Join Date: Jan 2009
2009 V6 4wd Base |
#9 (permalink) | |
Country: Join Date: Aug 2007
What you might find surprising is that icing can occur even on a summer day if the fan speed is set so low that the warm air is not sufficient to keep the coils warm. Since the evaporator coil is inside the vehicle, it is also possible that the evaporator temperature can be above 4'C even when outside temperature is well below that temperature.
#10 (permalink) | |
My speculation/interpretation is that a sensor on the evaporator/airbox will keep the compressor/condenser working as long as the evaporator core is not in the near freezing/iced up temperature range. With the temperature selector is in the heat position you're getting a blend of heated air to moderate the ice-up effect at the core. This compressor cut-out effect can also be observed in the summer when outside temperature is definitely higher than freezing, but the evaporator core can still iced up due to localized high humidity condition. Any merits? Edited to add RickL beats me to the post. Thanks.
