ABS, VSC dashboard lights are burned - Toyota RAV4 Forums : RAV4World.com
Old 01-05-2013, 08:38 AM   #1 (permalink)
Country: sarmadrav4's Flag is: Iraq
Default ABS, VSC dashboard lights are burned
My cluster instrument dashboard lights for ABS and VSC are burned as they never lit
is it easy to replace them or should I change the whole cluster and speedometer
Thanx
RAV4 2007
base trim
sarmadrav4 is offline   Reply With Quote
Old 01-05-2013, 08:56 AM   #2 (permalink)
Those lights are tiny LED's soldered on a circuit board. Not easy to change unless you have very good soldering skills. How do you know they are burned out?
Old 01-05-2013, 08:59 AM   #3 (permalink)
they never come on even when ignition is ON before starting the car.
Old 01-05-2013, 10:04 AM   #4 (permalink)
If you bought the RAV4 used, you might want to use the Techstream software to look for codes that the lights could have revealed.
Old 01-05-2013, 10:40 AM   #5 (permalink)
Rickl's Avatar
There is a very small chance that a LED has burnt out, and almost zero chance that two of them have burnt out.
How about the LSD, SLIP, and Downhill assist lights, are these working. These lights are all driven by the same LED Driver circuit, which is more likely to go defective than two LED's.
Rick L Ontario Canada
The Following User Says Thank You to Rickl For This Useful Post:
pico (01-05-2013)
Old 01-05-2013, 11:36 AM   #6 (permalink)
In section 2-2 of the Owner's manual (page 160, 161 in the 2009 manual) there is an asterisk next to each indicator light discription for the lights that should turn on during the lamp test (ignition on). You might check for others that do not work.
Old 01-05-2013, 07:35 PM   #7 (permalink)
friendly_jacek's Avatar
It happened to me in Corolla. Lights on LED went kaput. I was surprised myself, but it happens.
Old 01-06-2013, 02:56 AM   #8 (permalink)
Guys the only lights coming when Ignition is ON are:
brake, LSD, Maint record, Oil , battery, Door, P/S,
No ABS, No Washer fluid, No VSC.
Dear Friendly jack, did u replaced the cluster or only the LED??
Old 01-06-2013, 11:36 PM   #9 (permalink)
Nope, I learned to live without it. Corolla has auto lights, so not so crucial to have.
