My Rav4 2007 has an AC problem - Toyota RAV4 Forums : RAV4World.com
Old 01-16-2013, 12:57 PM   #1 (permalink)
Country: Azikag's Flag is: Uganda
Default My Rav4 2007 has an AC problem
Hello,
My Rav4 has an AC problem. When refilled it works for 3 days cooling the car but thereafter, it blows hot air. I have taken it for checking at the Toyota dealer and was told to change the compressor which I did, but that has not solved the problem. Anyone know how I can deal with this problem? I need a functioning AC. Help. Thanks, Ems.
Azikag is offline   Reply With Quote
Old 01-16-2013, 01:57 PM   #2 (permalink)
Apparently it has one or more leaks allowing the refrigerant to escape the closed system. Have a specialist check it for leaks.
Old Bird......sometimes wise
Both with Tow Prep Package
Old 01-16-2013, 02:14 PM   #3 (permalink)
Blogson's Avatar
There are florescent dyes which can be used by injecting them into the system to detect refrigerant leaks and there are leak detecting instruments which can be obtained (rather pricey to buy - maybe it would be possible to rent one even in Uganda). If the leak is with the evaporator it will be more difficult to locate since that part is located behind the vehicle instrument panel (dash). As RF suggests it probably would be best to have a trustworthy technician attempt to locate the leak, if that is possible.
Jim
2011 Upgraded Base V6 4WD
2002 Craftsman LT1000 V2
Jesus is Lord
