Rav4 Remote Starter Installed - Toyota RAV4 Forums : RAV4World.com
Old 01-28-2013, 10:36 PM   #1 (permalink)
Country: mikeinnj's Flag is: United States
Default Rav4 Remote Starter Installed
Hey Everyone,
A while back I asked about using an aftermarket/eBay remote starter that uses the factory keyfob and no one on here had yet installed/used one.
I finally broke down, bought it and got it installed tonight.
The eBay Listing for the one I bought
The actual product install guide
$99 and so far it works perfectly. It is a 'Flashlogic' brand and is made by Audiovox. Install took a little over an hour (This was outside in the dark). This was my first remote starter install. Sorry no pics.
The nice part about buying it from this seller is that the module is already programmed for our cars. This is a remote starter AND immobilizer bypass all in one. Many times this is two separate components to buy. Also, this kit came with all the harnesses/wires that are unnecessary taped off and a quick instruction guide. This was also the only kit I could find that specifically said it was made for a Rav4 WITH smart key AND push button start.
The install was fairly simple. 6 wire splices and a ground.
-3 wires spliced in to the ECU behind fuse box cover for Ignition, 12v constant, and the start/stop button.
-2 wires just underneath the ECU at the OBD2 port for CAN-Hi and CAN-Lo signals.
-1 wire to the parking light switch in the steering column. Bottom of column just pops off.
-1 wire to the ground bolt behind the drivers kick panel
I used those little plastic automotive grade wiretaps for the splices. The start/stop button wire is on the back of the ECU panel so you need to slither into the footwell to see what you're doing.
Also, the kit comes with a 'hood open' switch that is supposed to tell the module if the hood is open. I didn't want to run that whole ordeal and just didn't connect the wire to anything. The switch just grounds the wire if the hood is opened. More for insurance/legal reasons they probably had to do this. Kind of like the parking brake wire for aftermarket gps/dvd units.
As for the operation itself, press lock button 3x and it starts. Another 3x to shut it off. Open the door, the engine/car shuts off (Which is fine).
Also, you can change settings on the module like the run time. Default is 15min. You can set it in 5min increments up to 35 minutes. You can change the lock/unlock settings for when you start/shutdown.
Any questions, let me know. Just wanted to let everyone know that there is an easy and relatively cheap alternative to the VIP Remote Starter out there. Works great, very clean install. I was a bit hesitant to do this myself since I've seen other kits with an insane level of complexity. All the necessary wires were nicely heat shrinked/wrapped and the kit even included an extra set of REALLY simple instructions that are much easier than the official guide that I linked earlier. This is my favorite mod to the Rav4 so far. Would highly recommend for any Limited owner.
2009 Rav4 Limited V6 AWD Blizzard Pearl - AVIC-Z130BT
mikeinnj is offline   Reply With Quote
The Following User Says Thank You to mikeinnj For This Useful Post:
Dr. Dyno (01-29-2013)
Old 01-29-2013, 12:03 AM   #2 (permalink)
Thanks for the great review, Mike! Does this seller also have a version for the non-smart key versions? Also, your second link doesn't work for me. I get a 401 error:
Authorization Required
This server could not verify that you are authorized to access the document you requested. Either you supplied the wrong credentials (e.g., bad password), or your browser doesn't understand how to supply the credentials required.
Old 01-29-2013, 07:30 AM   #3 (permalink)
superb! I would have done the same. I already got mine installed last year by a pro.
But I love what you did.
May be the hood wire is used to prevent someone from starting the car with the remote while someone is working in the engine bay.
I know I don't have this feature on my remote.
Old 01-29-2013, 08:32 AM   #4 (permalink)
Thanks for the post! An hour is almost unbelievable!
I spent more like a day in my nice lighted garage a couple years ago installing my add-on remote starter. And my field is electronics.
This kit and the specific instructions are obviously quite a bit more user friendly.
I'd install the hood pin if I was you. It is a safety item.
On mine I defeated both the shutoff on opening the door (for which you must use the physical key on my non-pushbutton model) and on touching the brake pedal. Seemed to me it just meant an extra start every time. But it did cause a surprise problem. I figured you had to insert the key and turn it to unlock the steering anyway so you couldn't drive off remote started. Turns out you can unlock the steering by turning the key one position to ACC but you haven't turned the ignition on until the second position. Wife called saying the car just completely died a mile or so from home. NOT GOOD.
She thought she turned the key two clicks but obviously had only done one. It doesn't happen often since I have the run time set to 5 minutes and it has often timed out before she leaves. But I guess I better hook one of the shutoffs back up to wifeproof it.
2006 RAV4 V6 4WD Red Limited
Old 01-29-2013, 08:37 AM   #5 (permalink)
I fixed the install guide link for those interested.
The seller looks to only have the kit for Push button start Rav4s. However, finding a kit for a Rav4 without push button seems a lot easier. I found one from a different seller that looks to have the same exact module in the picture (The 'Omegalink' module has the exact same ports on it) but is for regular ignition Rav4s.
Add Remote Start to Your Toyota Use Your Factory Remotes to Start The Car | eBay
As for the hood switch, I would have to drill into some part of the plastic trim somewhere along where the hood meets the engine bay. That and run the wire through the firewall. I may connect it this spring if I get ambitious. I'll probably be adding a small subwoofer and thus running a power cable through the firewall.
Old 01-29-2013, 11:09 AM   #6 (permalink)
pico's Avatar
Here it is. Hope this helps.
pico is online now   Reply With Quote
Old 01-29-2013, 11:28 AM   #7 (permalink)
KTL
Country: KTL's Flag is: United States
That's interesting that you don't need to cut the starter wire to interrupt the signal. If you don't want to drill through the plastic and metal for the hood switch, you can always get a mercury tilt switch as a replacement. I've used those before during my mobile installation period and they seem to work well. But I'm not sure what's the angle of tilt that would trigger it during an incline/uphill.
KTL is online now   Reply With Quote
