Same circuit; they work at the same time.
I don't think Techstream can be used to enable or diable part of the circuit. I did not see any such options for my 2008 RAV.
I bought a set of aftermarket heated mirrors with the turn signals light built in, and I was able to wire the heated mirrors to a toggle switch with little trouble. It is possible.
Hi, I am new here. I have a 2010 Base RAV4 (US version) with no heat mirrors. I checked around difference websites, and realized Japanese made and US made are difference. Mine is a Japanese made version, and I have already found the power heated mirror on Amazon.com with the turn signal feature. The connector on the other side (not the mirror side, it only has 3 wires on the mirror side) has 9 pins installed. If I order the power, heated, and turn signal mirror, will all features work right away?
Thanks
