I've been looking for a set of alloys for my '06 Base, thinking that I'd use the steel rims for my snows. I've been hoping to find a set of 17" OEM alloys because, IMO (and correct me if I'm mistaken), 17" tires ride smoother than 18s because of the additional sidewall.
So, I found a set of alloys off a 2010 RAV but they're 18". This got me wondering if 17" alloys were even available.
Thanks,
Willie
You would also need to make sure the tire circumfrence and diameter are the same for the base wheels and rims vs the Limited's 17", which I am sure others may be able to help you with.
There were 2 different aluminum 17 wheels available for the 4.3 rav....5 spoke on the value package and 6 spoke on the limited ....the ride on the 18s would not be that bad since you have the base model suspension......the sport gets a lot of it's harsh ride from the suspension as well as the tires......but also remember that with the 18 inch wheels it will handle better......
I'm all in favor of improving the handling but not if its at the expense of comfort. Knowing that the softer Base suspension is the main reason for the softer ride is comforting (pun intended). I also have to wonder if the diameter of the tire on an 18" rim is going to be larger than a tire mounted on a 17" rim. I'm guessing not because it would require different gearing (or programming?) for the speedometer. Any thoughts on this?
Willie
I think they wanted to give the base a sport look to it......I prefer those over the limited ones.......of course I put aftermarket wheels on anyway.......
Thanks for proving me wrong with respect to the diameters. Based upon all the responses, I believe my wisest path forward is to get a set of 17s. Any one disagree?
BTW, thanks to those who posted pics of the 2 styles.
Keep in mind that the Base V-6 came with styled steel 17" wheels. I know this because we own one. Just mentioning this for possible winter wheels for you folks in the great white north.
keep your eye on craigslist......i recently sold a set with decent tires and air pressure sensors for 300 bucks......just wanted then out of the garage....
