Country: |
Aftermarket, yes.
From factory, no.
2009 Toyota RAV4 Limited V6 4WD Auto - Pacific Blue Metallic - Leather - Tow Prep - Trailer Hitch
-- OEM Hood Deflector -- Upgraded Horn -- LED Interior Lighting, Backup, and License Plate -- Yakima Roof-Mounted Bike Rack -- ![]() |
Country: Join Date: Nov 2008
It's only a $40 option on the window sticker, so there can't be that much to it. I know there are 3 relays in the circuit.
2011 is just one relay AFAIK, if your 06 has same socket, I guess you could just plug it in :P Although 2011 also comes with a light sensor under the windscreen, if you don't have that, then surely 2011 way is out of the question.
This forum has repair manuals in a sticky thread, should not be hard to figure it out. |
I understand that DRL goes through the high beams, right?(with reduced power or sth...)
I have an European version of Rav4 and low beams turn on with ignition starts. Is it possible for me to activate DRL on high beams? |
#8 (permalink) | |
Country: Join Date: Jul 2011
I have a 07 Limited. I do not have DRLs. Has anybody succeeded in adding DRLs? Is it as simple as putting in the three relays and enjoying the DRLs or is there more to this? |
#9 (permalink) | |
Country: Join Date: Aug 2007
According to the diagrams the normal high beams would not operate properly if any of the 3 relays were missing. I cannot find anything in the drawings that shows any optional wiring for cars sold without DRL's. Based on the diagrams I suspect all RAV's are wired the same way, and the DRL's are controlled by a signal from the ECM. Perhaps this is an option that can be turned on and off with the Techstream software, Have you done a physical inspection to see if these relays are missing from your RAV4?
#10 (permalink) | |
I have not yet done a physical inspection but that sounds like a good next step. The car is outside now and covered by snow so the inspection will have to wait a bit though... |
