Just took my 2007 RAV4 to a 3rd party to have a trailer hitch installed. They were able to connect the 2 bolts closest to the bumper. But, they couldn't connect the other 2 bolts closer to the front because the place-holder bolts were missing and the holes and threading were completely rusted. They recommended having the hitch welded to the frame.
My biggest concerns about this are towing safety and possibly having to remove/replace the hitch someday. Would having only 2 bolts + welding be secure enough to tow the max 3,500 lbs? And would it be possible to remove a welded hitch well enough to install a new one if needed? Thanks! 2007 RAV4 6 cyl 4WD w/tow pkg |
I am not sure I understand "2 bolts closer to the front because the place-holder bolts were missing and the holes and threading were completely rusted.". Is there rust on your underbody?
However, my opinion would be NO, don't let them weld it to your car. There is no "frame" to weld to on a unibody vehicle, but rather sheet metal. The strength comes from the whole "unit" making a solid truss-frame-like unit. There is not much "point" strength, that a weld depends on. Honestly, if someone suggested this to me I would be looking for a different installer. JMO, Tommy |
#3 (permalink) | |
Country: Join Date: Aug 2007
Rick
Welding is fine and even stronger than the bolts. If they do a good job at it, and you don't plan on ever removing it, I'd say to go for it. I know the bolts you are talking about and I was lucky enough that the bolts that go in them were already there and not too rusty.
Same thing was wrong with my 2008, I drilled and tapped the holes to the next larger std american thread size, worked fine. no welding.
Thanks for all of the feedback! Taking it to the dealer to see if they can drill and tap the holes a size up... and to get a second opinion. I got it used 12 mo ago and it was Toyota Certified, so hoping it's all under warranty, since its their fault that the bolts were missing.
#8 (permalink) | |
As far as I know Toyota does not put any bolts in the empty holes. They just pre-tap the hole and leave it like that. Rick
#9 (permalink) | |
Country: Join Date: Nov 2008
Hmmmm.....for someone like me who may want a hitch in the future maybe I should thread some placeholder bolts into those holes. Does anyone happen to know the thread size?
#10 (permalink) | |
One of the holes on the drivers side is being used to hold on the "tie down bracket". The second hole on the drivers side, and both holes on the passenger side are empty. Rick
