My rear mudguards(00016-42714 w/o flares) do not line up to the screws that are there. I attached a pic to show what I mean. I called the dealer and he was clueless on what the issue could be. The front ones are fine and fit ok. I am guessing I have the wrong ones, but it seems like these have been the same model mud guards for the past 5 years. Any ideas? Thank you!!
Wow. No idea. Mine went on pretty perfectly, maybe a touch from flush in a couple places if you take the time to look. Nothing like that. If it butts against the underside properly, I'd be tempted to just poke a new hole and use a retainer clip.
I just put a set on an 2008 RAV limited I purchased. The rears don't use all existing holes. I think it was the top most one that lines up and the botton two of them required a screw to be turned through a dimple in the plastic and through a retaining clip furnished with the mud guards. I will take a look a bit later and verify.
Country: Join Date: May 2011
I had the same problem on my '06 model, I just made a "new" (there's already dimples on where it should be) hole, i think it was only the top/bottom for me that didn't have a hole. I don't remember if I used a retaining clip, the rear gave me a problem and I just made the holes.
I thought the dimple was a couple inches above his flare's screwhole? either way, the easy solution would be to lightly mount the flare with the existing holes, jab the cover with a nail or something, install the clips, screw everything together. That's what I did, took maybe 20-25 minutes with my Leatherman Micra. Would have been 10 minutes if I had my little right angle allen tool handy. The dimple won't bother anything, it was there before you installed the flares.
That's assuming the flare lines up properly otherwise. |
#7 (permalink) | |
#9 (permalink) |
When I installed mine (couple of years ago) I believe there were two holes existing and one or two holes that you had to make. I remember it came with extra retaining clips. I just installed it with the existing holes and when I was satisfied that is when I added the extra holes. Simple to do since the plastic is really soft.
